Converted to carb! TC lockup switch or not?
Old Oct 1, 2004 | 08:03 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
OK guys, I converted from TPI to carb, and still have the 700r4 in the car.
The computer is gone, so should I buy a TC lockup switch, or will wiring in a toggle switch work?
What will happen to my trans if I just leave it this way?
I will be having the trans built later on, and thought about using a non lockup converter. So I will have to have the trans converted also.
This is not a daily driver, but it does see some street time.
What do you guys suggest?
thanks
Old Oct 1, 2004 | 08:16 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
Just make a switch.....since its not a daily driver you are better just using the Lock-up when you need it.......save you lots of money and YOU have the control over it.....
Old Oct 1, 2004 | 08:58 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
yeah, but will a typical toggle switch still work with the computer out of the car?
I know it will work if you are still using the FI and computer, but will it still work the same without the computer?
Old Oct 1, 2004 | 09:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As long as you don't butcher the wiring.
Old Oct 1, 2004 | 09:49 AM
BIGJON's Avatar
Yes make sure that the switch is providing a (GROUND) or a negative signal.....thats what completes the lock-up...
Old Oct 1, 2004 | 10:24 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I did remove some of the wiring. The wires for the injectors and ect.
I did not touch any wires going to the trans.
What would be the down side of not using a switch? Besides using more gas at highway speeds?
Old Oct 1, 2004 | 10:32 AM
BIGJON's Avatar
Well your torque converter when not locked up will produce friction and therefor create more heat.....this is not a major concern but you gain a few hundred rpm on the highway and you will have less friction (heat) built up in the transmission that way as well.....I have a Camaro that I don't use it on and my Firebird I do for highway driving and thats it.....
Old Oct 1, 2004 | 10:46 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
so if I install a external trans cooler, then that would help with the heat/friction. Im not worried about the extra few hundered RPM. I run 3.73 gears anyway.
I do race it from time to time at the track. I also do drive it around town on occasions. No freeway driving.
Thanks guys, I may wire up a toggle switch just to see if there is much of a difference.
Old Oct 1, 2004 | 10:49 AM
BIGJON's Avatar
Right it isn't a critical component but it is more of a preferance.....
Old Oct 4, 2004 | 07:25 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
thanks.
Old Oct 4, 2004 | 10:02 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i just got rid of my computer when i dropped in my 350HO.
I'm running a 700R4, B&M shift kit, and a supercooler.
w/o the lockup it added 200 rpm at cruise, comes out to about 1700RPM@60MPH w/ the 2.73's....
I'm more worried about my tranny leaking, than the lockup at this point...
I did save the tranny wires though, in case i ever get around to it.
Brandon
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
