Clucking from rearend when i slow down
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok guys, i've never thought much of it until now.
FOr the past iunno how long, sometimes my rear end will clunk sorta the whole thing move forawrd when i slow down. Never feel a clunk when i accelerate just when i slow down and only sometimes, there is no way i can see to do it for you, it just happens somtimes.
What could it be?
What could it be?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine is doing that too. you can also hear it clunk if you tap the gas quickly.
It could be the Torque Arm bushing, pinion nut, tranny mount, u-joint, etc...
I ordered an Energy Suspension Torque Arm bushing for my Formula today and maybe that will get rid of my clunking since everything else looks good.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Yeah i mean i looked under there and didn't notice anything missing or anything, bt i got my mechanic to even look at it and he still saw nothing he took it for a test drive and it didn't want todo it for him, i dont know what it could be.
My 9 bolt does that in my 89 formula,, nerver did it till i put on lca's and took it to the track
but it was really clunky going over gravel roads,, I allso checked it , and could not see what was making the noise, maybe axles are loose or bearings prehaps, no clue ? either way soon as my new motor goes in im sure i will put my rearend in the junkyard
and in goes a strange or moser.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check your U-joints. I betcha one is broken or worn out. Might even just be a loose bolt holiding the U-boint on.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
sure its not a chicken?
sorry couldn't resist, don't you hate how you can;t edit your titles
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Clucking from rearend when I slow down
Keep running...eventually the chicken will just fall out. :lala:
Sounds like a tranny mount...
UltRoadWarrior9
Apr 28, 2020 10:39 PM
RedLeader289
May 28, 2019 01:47 PM
