posi and gears
Old Nov 2, 2004 | 05:38 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
posi and gears
I have a buddy with an '88 TA in which he just dropped a warmed up 350 in. I'm just looking for a few opinions to help with his gear selection. The motor has a crane cam with lift@ .454/.480 with like a 272/282 dur. or pretty close i think, a stage2 750 cc q-jet from jet, edelbrock rpm 2.02,1.60 heads, edel. rpm intake and a well worked over 700r-4. I was telling him to go for some 3.73's but we were also pondering on 3.42's....I would appreciate any positive opinions based on his engine specs.
Old Nov 2, 2004 | 06:12 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
What's his ACTUAL duration ar .050 of lift? Roughly speaking the 3.73's sound like they'll be optimum, that's of course assuming a actual duration in the 230 range complimented with a 2800 stall.
Old Nov 2, 2004 | 06:23 PM
the adv. duration of the cam is 272/284 but the duration @ .050 lift is 216/228.
Old Nov 2, 2004 | 06:25 PM
he has a 2200 sc.
Old Nov 2, 2004 | 06:27 PM
IHI's Avatar
IHI
That's changes everything 3.42's would be optimum with a 2000-2500 stall.
As for opinions on his combo, it should make for a fun torquey stoplight to stoplight ride. Would've like to see more actual duration, but it should still be a fun car.
Old Nov 2, 2004 | 06:31 PM
Thanks IHI, for a while we thought the 3.73's would be a bit of overkill but we weren't quite sure.
Old Nov 2, 2004 | 06:33 PM
what kind of times would you expect him to pull if he drives it well?
Old Nov 2, 2004 | 06:36 PM
IHI's Avatar
IHI
Honestly if he hooks & depending on the weight of the car I would venture to guess mid to high 13's.
He's really got the right parts to make a strong runner, after he gets bored with this set-up a larger cam-not stupid large either-will really compliment the rest of the components he has. Seems that's the weak link right now in that combo...and your altitude.
Old Nov 2, 2004 | 06:39 PM
Yea, I thought at least 13's too
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
