700R4 question
Old Nov 3, 2004 | 09:27 AM
hot91t/a's Avatar
Car: 1991 Trans Am
Engine: built 305 carbed
Transmission: built 700R4
700R4 question
i have a 700R4 with a lock up on it and i have no idea what that means, if someone can answer that it would be great. thanks
Old Nov 3, 2004 | 04:12 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Basically, lock-up is is when the torque converter clutch locks itself to the torque converter housing, causing a perfect 1:1 ratio between the engine flywheel and the trans. input shaft. All torque converters slip to a certain extent and this is just a way to prevent it. It just helps improve fuel economy at higher speeds (+35 mph).
Is that making since?
EDIT: Here's a write-up on how torque converters and lock-up works. It's explained much better than my explanation .
http://auto.howstuffworks.com/torque-converter.htm
camaro11j
Sep 19, 2018 08:49 AM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
Leggman1
Aug 6, 2015 04:15 AM
