Tranny fluid burn??
Old Nov 13, 2004 | 05:46 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Tranny fluid burn??
Ok, this is going to be a theoretical question since it doesnt have to do with an f-body, or even a GM vehicle...
The tranny is leaking, it's controlled by a vacuum modulator, and it's thought to be the vacuum modulator is leaking, can tranny fluid be sucked through the vacuum modulator into the manifold to be burned?
I dont think so, but i'd like to know for sure.
There are no other leaks, the tranny is clean as a whistle. It's not leaking from the front seal or the rear seal and the pan isnt leaking either.
Thanks.
Old Nov 13, 2004 | 06:17 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Yes it is possible and has happened to alot of people before. Usually, the diaphragm will rip causing the engine vacuum to suck the fluid out. One of the guys that I work with used to work for a Corvette shop and the customer was complaining about weird shifting. When he pulled the car into the shop, the diaphragm ripped, sucked the tranny fluid into the motor and caused it to stop. Then, there was no vacuum to operate the brakes and he hit the wall with the car.
Old Nov 13, 2004 | 06:21 PM
Car: 88 Camaro
Engine: 310 LG4
wow, i guess i stand corrected then. So the obvious answer is to replace the vacuum modulator then?
Old Nov 13, 2004 | 06:25 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
that is correct. but i dont run those things cause the man caint hold me down, controlin my shifts, i control my own shifts. freak what ya heard....
Old Nov 13, 2004 | 06:28 PM
paulmoore's Avatar
I would just to be on the safe side. The story that I told was a worst case scenario and probably wouldn't happen to your car. I think that some of these new shift kits come with stuff to do away with the governer/modulator for more accurate and precise shifts. I could be wrong though!
Old Nov 13, 2004 | 06:32 PM
Car: 88 Camaro
Engine: 310 LG4
hell no, this aint my car, this is a Ford Areostar minivan lol! My baby runs a 700r4 with a tv cable, that vacuum modulated crap is for the birds and fords. I cant believe ford still sued vacuum modulators in 93. GM stopped in 86-87?
Old Nov 13, 2004 | 06:48 PM
ljnowell's Avatar
What you said is the exact opposite. Why GM got rid of the vacuum modulator is the real question. The TV cable system isnt worth a damn, ask anyone that has had a ruined trans because of it. Simple fact is, they replaced a system that worked fine for something that was worse. Thats the good ol' general motors for ya.
Old Nov 13, 2004 | 06:56 PM
Car: 88 Camaro
Engine: 310 LG4
i beg to differ on that statement, the problem with TV cable is people not setting them up correctly.
http://www.tvmadeez.com
check it out for tons and tons of info.
Old Nov 13, 2004 | 11:01 PM
ljnowell's Avatar
I dont need to check it out. You can think what you will, but ask the poeple that were around before the TV cable system. The vacuum modulater was a perfect system that had fewer flaws. It performed perfectly, and was killed off for a worse system. You are right about one thing though, people do not set them properly, that is one of the flaws in the system. When two clicks of a cable can toast your trans, that is no good. Do some more research and see what you come up with.
edit: Hey, we do the same thing!
Old Nov 14, 2004 | 09:27 AM
Car: 88 Camaro
Engine: 310 LG4
I agree about how easy it is to kill off your tranny by two clicks, but i'm not worried. I've had plenty of research, i worked for (at the time) the best 700r4/2004r shop around. Anyway i dont want to debate anymore, i got my answer, so thanks for the info.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
bjpotter
Oct 4, 2015 07:48 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
