What Overdrive is in my T5?
Old Nov 15, 2004 | 07:41 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got the T5 out of my friends 88 GTA with the 3.45 9bolt.
On the highway with 3.73 gears in 5th at around 70-80mph I am taching about 3K.
I thought I had a .72 OD, but I was reading a site and they mentioned a .85 OD.
Old Nov 15, 2004 | 11:30 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
Most T5s came with .63 overdrives. A very few got a shorter overdrive but those were mostly later 1LE cars. Mine has the .63 overdrive and with 3.42 gears my turns 2500 at 70mph.
Old Nov 15, 2004 | 12:05 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
all non 1LE cars got the .63..the 1LE's got the .73.....there wernt anyother overdrives but those 2...
with the 3.42's and .63 overdrive
1,500 at 45 mph
2,000 at 60 mph
2,500 at 70 mph
2,800 at 78 mph
3,200 at 90 mph
Old Nov 15, 2004 | 05:59 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
Axoid--nice SOLO II foto...does the steering brace make much difference? Did you choose 3.42's over 3.23's for SOLO?
Old Nov 15, 2004 | 09:58 PM
cully6159's Avatar
Car: 1987 camaro sport coupe
Engine: 355
hey Axoid i was wondering where you got your rims from if you had them made or there just gta rims thanks
Old Nov 17, 2004 | 09:28 AM
Axoid's Avatar
Car: 92 Camaro RS
Thanks,
I didn't did notice a difference with the steering brace, but is was one of the first mods that I did and at the time I was still newbe and running 16x8 wheels. I'm now running 17x9.5s and I sure there is more stress going though the steering now than before. Plus the car was very solid when I bought it, so it may of not needed it then.
Yes, the car came with 3.08 gears and the 3.42s were the largest legal ratio. I occasionally get into the 6000 rpm range in second but not often.
The wheels are 17x9.5 3 piece CCW track wheels. www.ccwheel.com
Old Nov 22, 2004 | 09:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
L69 cars got the .73 gear too.
Old Nov 22, 2004 | 09:58 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Thanks Axoid--not much SOLO II activity in West Texas--rats. My car's very solid, too, and I want to keep it that way--maybe see you in Topeka next year.
Old Nov 23, 2004 | 09:26 AM
Axoid's Avatar
Car: 92 Camaro RS
There's a lot of SOLO II here in the mid-west. I may go to Topeka next year, depends on how things go in the first half of the year. I am going to run some CenDiv events (Divisional Championship series) next year.
Old Nov 24, 2004 | 08:11 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Excellent--I want to set up my '82 for E street prepared, too, and I haven't sent off for the SCCA rule book. I currently have 3.73's and was gonna change to 3.23's because of the distances out here, plus when I get to the mountains in New Mexico the 3.73's are just too deep for my stock 305.
If you were going to run on the street, lots of highways, and the mountains and E street prepared now and then, would you run 3.42's or 3.23's? Would 3.23's make my car non-competitive? I don't have to win every time but I wouldn't want to handicap my car--thanks.
Old Nov 25, 2004 | 06:29 AM
Axoid's Avatar
Car: 92 Camaro RS
I don’t think 3.23s will hurt you much if at all, specially if you have plenty of long runs.
My car isn't a dedicated autocross car; it sees its share of street and highway driving.
Old Nov 26, 2004 | 01:32 AM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
I have a 1990 camaro with a t5 and 3.45 and at 2000 i hit 80.
Old Nov 26, 2004 | 07:47 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
you dont have 3.45's..you have 3.08 gears if you hit 80@2000
its actually 79.75mph or 2006 rpm
Old Nov 27, 2004 | 12:09 AM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
My stock 1983 T-5, behind the LG-4, came with the .73 overdrive.
My car was also a WS-6 car with the 3:73 limited-slip diff.
Old Nov 27, 2004 | 01:30 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Got a build sheet? I'd like to see a factory LG4 / 3.73 car.
Old Nov 27, 2004 | 10:52 AM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
My car has a 3.45 9 bolt rear end that came of a 1987 firebird. I now what my car has. It does 80 at 2000.
Old Nov 27, 2004 | 01:26 PM
1tinindian's Avatar
A mystery no longer:lala:
Old Nov 27, 2004 | 02:52 PM
Zepher's Avatar
If you had a gear ratio numerically lower than 3.45 and didn't recalibrate your speedo gears, then your speedo is reading high.
Old Nov 28, 2004 | 02:21 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
My speedo is perfect. I got a radar gun and did it. And also did it on the high way with my buddy. He also told me that i was doing 80. Beleive me that it is right.
Old Nov 29, 2004 | 12:12 AM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axoid--thanks--I'm going with 3.23's then--got to get that rule book.
Old Nov 29, 2004 | 06:40 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
there are 2 things that are possible here..
1. your car has 3.08's
2. you tranny has a .56 5th gear
3. your speedo isnt calibrated for the 3.45 gears
there wasnt ANY .56 5th gear....
now do us all a favor and go the the EQUATIONS section on the main page...
under the MPH equation put in 13 for tire radius, 2000 for engine RPM, 3.45 for rear end ratio and .56 for tranny ratio...that equals 80 MPH...once again THERE WASNT ANY .56 5TH GEAR
now put in 3.08 for the rear end ratio (since that what LO3 cars got) and .63 for the tranny ratio (since that was LO3 cars got) that equals 80 MPH....
and just for your information the 9 bolt wasnt available in 87 firebirds...only 88-89 GTA'S
Old Nov 29, 2004 | 08:28 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
This reminds me of my '58 BelAir in 1966 with the 348 and three 2's--I knew what I had.
Prodigious
Nov 7, 2020 09:23 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
wisemanz28
Sep 20, 2015 01:26 PM
84 TA NV
Sep 6, 2015 08:02 PM
