Is my rear end trashed?
Old Nov 17, 2004 | 03:02 PM
Slow2.8's Avatar
Every time, well everytime i take a left turn with a little more speed than an average turn (not fast fast) it makes this clunking noise, sounds like it could be something wrong with the differential because it only does it on left turns.
Old Nov 17, 2004 | 03:05 PM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
could be a broken coil spring or a bushing beat out, id check that out first.
Old Nov 17, 2004 | 10:13 PM
Slow2.8's Avatar
that sounds alot better than it being in the differential. When i get the 100 bux im going to get the polyurethane bushing and replace all those (w/ the black ones so they dont squeak). While replacing them i'll check out the coils.
Old Nov 17, 2004 | 11:42 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Its f*cked...
Isn't that what you wanted to hear?!?!
j/k man... sounds like a possible problem in the rear... check everything exterior first... loose bolts etc...
Old Nov 18, 2004 | 10:27 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Id also carefully check teh panhard bar, bolts, and all the bushings there. I was having a similar problem that was caused by one of the bolts not being tight enough and it would move around when under load.
Old Nov 20, 2004 | 10:27 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Could be a problem with the spider gears.
Old Nov 20, 2004 | 10:31 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
My 87 was making a similar noise. It was the rear control or trailing arm bolts. One of them wasnt tight enough and it made a thunking noise when I turned. Also check that your tranny mount isnt trashed. That would make a loud noise when you stepped on the gas. Do you like to go fast into left turns
Old Nov 20, 2004 | 12:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I would agree with the rest. Gotta be something else. The rear end would make noise all the time. maybe get a $20 inspection at a local garage. They just put it on the lift n look for bad stuff.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
