Loud thump when it first starts to move.
Car: 1989 Firebird
Engine: 2.8L V6 MPFI
Transmission: Beat to heck 700R4
1989 V6 2.8L MPFI. Auto. Just about every time I'm driving, if I hit the gas with any kind of authority, I get this loud thump from under the shifter hump. Its a little further back, like under the armrest even. Its fine till I stop again, then it happens as soon as I give it even a little bit of gas. I can hit the gas so it doesn't happen, incredibly gently, but the cars behind are pissed off then LOL.
Always happened like that in this car (had it for 4 years now). The severity of the thump, (which can be felt, and heard), is directly proportional to how hard I hit the gas.
Any clues? Is my tranny jumping around down there?
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by 84camz28
yes it sounds like a trans mount to me
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
btw, trans mount is about $12... i reccomend a poly one...
its just two bolts on the trans, and one or two thru the crossmember... first time might take you 20mins.. after that, its a 10min job.
Car: 1989 Firebird
WOOT!
Oooh, thanks guys, and yep, thats exactly right Mrdude.
I'll look into it this weekend.
Recommendations on where to get one?
go to your local autozone, checkers, napa. any one of those will have what you need
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i had that same problem all summer and we couldnt find the problem until i went to the place where i got my exhaust done and the guy showed my it was the trans mount i should have thought so because there were pices of it hanging under the car. btw my replacement part was only like $6.50 but now it drives like a compleatly diffrent car
