Is my trans dead?
Old Nov 23, 2004 | 12:47 PM
StealthElephant's Avatar
Car: 87' Iroc
Is my trans dead?
Yesterday and today the 3-4 shift was coming in late. Like 1000RPM later then it normally does. Then my 1-2, 2-3 shifts began coming 1000RPM late and banging into gear when they do come, and I can be going 45MPH in 3rd gear with my RPMs at like 2500 and it will not shift into 4th gear. So my 1-2, 2-3 shifts are now coming in very late, banging into gear, and I don't have 4 gear anymore. Before I tell my parents my car is DOA, it's pretty safe to assume the trans is on it's way to completly dying right?
I checked my fluid level with the car hot and idling, it's perfect. I checked my TV cable, it's the same as it has always been.
Old Nov 24, 2004 | 02:53 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
sounds to me that you could use a rebuild my trans started doing the same thing when i was 120 miles from home after 30 miles i only had 1st and 2and but i made it home with 2 gears and drove to and from work for a month till i got it rebuilt
Old Nov 24, 2004 | 04:30 PM
Car: 87' Iroc
Well today it acted normal. I never went into 4th gear (drive to work is only 1 mile, all 25 MPH). 1-2, 2-3 shifted normally. Could it just have been some dirt in the valve body or something?
I think I'm gonna replace the filter and fluids.
Old Nov 24, 2004 | 10:00 PM
sellmanb's Avatar
Car: '86 Berlinetta
The servo is in charge of 1-2 shifts, and somewhat on the 2-3 shifts IIRC. They're about 15 dollars SHIPPED via eBay. That's how much I got mine for, it has all the gaskets and everything I could need, look for a Corvette servo... they have roughly 35% more grab area IIRC.
They're also really easy to install.
http://sethirdgen.org/servo.htm
and
http://www.impalassforum.com/tech/dr...nsgo_servo.htm
have been invaluable sources for the swap
the corvette servo also increases transmission life expectancy because it will shift into the gear faster, thus less wear on both gears between shifts.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
lt1z350
Aug 28, 2015 05:57 AM
spaigo
Aug 21, 2015 07:46 PM
Bradsaundry
Aug 12, 2015 12:34 AM
hokis
Aug 9, 2015 03:57 PM
