How do I take the gas pedal pad off?
Old Nov 24, 2004 | 03:19 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I just bought me a new pedal set and got the brake and clutch on fine but how does the plastic gas pedal cover come off?
Old Nov 24, 2004 | 07:32 PM
pasky's Avatar
Come now, certainly im not the only one who has picked up a pedal set?
Old Nov 24, 2004 | 09:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i've taken them off other GM cars and it just folded over the pedal with a lip around it. I'd check that out first. i doubt it's screwed into the pedal.
Old Nov 25, 2004 | 11:25 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
heres a quick illistration .. pretty much theres a pin that holds the pedal on the rod..
Old Nov 25, 2004 | 11:28 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Nice drawing but he is asking how to remove the rubber cover on the gas pedal, not how to remove the gas pedal.
Old Nov 26, 2004 | 06:42 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Gas pedals are plastic all the way thru. There is not a cover.
With my pedal covers they screwed right into the plastic pedal.
Attached Thumbnails How do I take the gas pedal pad off?-pedals-installed.jpg
Old Nov 26, 2004 | 02:59 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Most just bolt or screw right over the old ones. [mine just bolt around them]
Its just a rubber pad man. Just pull n pry it off. It may take some effort but id make sure n see if the pedal don't fit on, with the old pads in place. Some times them kits account for that and removing the rubber pad makes them not fit tight.
Old Nov 26, 2004 | 03:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Nice how the gas pedal pad stick out around the edges but the hold down wont tighten enough without the pad there. Could trim it but naaaa who look at them that often.
99% of the reason I have them is for grip, not looks. Nothing worse them your feet slipping of the pedals from, oil,mud .......
Old Nov 27, 2004 | 07:29 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I need to quantify my response, my 90 did not have a cover the whole pedal is plastic. The hex pattern is molded right into the plastic. I don't know about earlier years or camaros.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TBRays98
Sep 6, 2015 05:05 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
