Widest Tread On 3rd Gen
Old Dec 4, 2004 | 10:40 AM
klumb15's Avatar
How wide can you go? can you go upwards of 295-315 for the rear tires? I jus wanna know how wide you can go without modifying anything or rubbing...
Old Dec 4, 2004 | 03:56 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Might get more answers in the Appearence section....
Old Dec 4, 2004 | 04:48 PM
klumb15's Avatar
ok
Old Dec 10, 2004 | 11:28 AM
frogmanjohn's Avatar
Car: 89 RS
Engine: 305 TBI 215,000+
Re: Widest Tread On 3rd Gen
i was running 275/60/15 cobras on stock 15 rims on my 89.
Old Dec 10, 2004 | 02:21 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I remember reading someone running 315's on 17x11 rims in the rears, but he had to roll the fender.
Old Dec 10, 2004 | 03:10 PM
klumb15's Avatar
how wide can you go on a 16x8 wheel? can you get 275 or 285 on there?
Old Dec 10, 2004 | 03:12 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
255 is the widest on an 8" rim.
Unless you want that old school bulgy look, you could fit 275 ..
Old Dec 10, 2004 | 07:45 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I saw a guy at the autocross last week with 265-45-16 on the stock iroc rims, but they are khumo sticky autocross tires and not regulare street tires.
Old Dec 11, 2004 | 07:20 AM
rawley2's Avatar
Car: 87 GTA Trans Am
Axle/Gears: 10 bolt posi 3.23
I have 225/50/16 on my car. The front rims do have an offset though. Or they may be 235/50/16.. I am not 100% sure and it's to cold to go look right now.
Old Dec 11, 2004 | 08:10 AM
1quikformula's Avatar
Car: 1991 Pontiac Formula
Engine: 350 C.I
Transmission: 700R-4
I'm running 285/40ZR17 in the back with no alterations
Old Dec 11, 2004 | 10:31 AM
klumb15's Avatar
on a 17x8" wheel or what? so I should be able to run a 265, or perhaps a 285 on a 16x8 if I want....or should i go with a 255 to be on the safe side....what does that do to your tire if you use too big of one and it bulges out?
Old Dec 11, 2004 | 10:36 AM
Engine: 350 C.I
17x9.5, I think the widest you can go on a 8 inch rim is 265, safely. My brother is running 265 on an 18x8, but not a third gen though
Old Dec 11, 2004 | 12:20 PM
klumb15's Avatar
alright...265 it is...if anybody comes up with an experience they had running a 265 on a 8" wide rim, please post it, so I don't make the same mistake..
Old Dec 11, 2004 | 01:51 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
I don't know the dude with the 265-45-16's that was at the autocross, but he was running that same size tire on all 4 stock iroc rims and was running good. They look stock if you don't look at the size on the tires.
http://www.tirerack.com/tires/Compar...rk=1&x=12&y=12
It looks like they are all non-street tires in the size.
ex-x-fire
Jan 12, 2024 01:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Warlocksirix
Sep 3, 2015 12:26 PM
zayne0
Aug 24, 2015 07:22 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
