Need Info on 89 firebird formula five speed
Old Dec 8, 2004 | 03:07 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
Recently my mechanic ripped a rear end out of an 89 firebird formula, it was the 305 TPI motor with a Five speed Transmission.
Would the rear end gearing be the same as the IROC-Z that came with the five speed? which in 89 was 3.45 for the 305
Old Dec 8, 2004 | 03:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it was a G92 car.
If it wasn't, it probably would have come with a 3.27.
It should be a 9-bolt with PBR brakes.
Old Dec 8, 2004 | 03:59 PM
Car: 83 Trans Am
how can i tell if they are PBR brakes? It does have disc brakes also.
Old Dec 8, 2004 | 04:11 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
in 1989 3.08 gears in a 10 bolt were standard equipment for 305 tpi 5 speed cars. the 3.45s were optional and were in a 9 bolt rearend.
ur mechanic should easily be able to tell what you have just buy counting the number of bolts that hold the differential cover on nd buy either counting the teeth on the ring and pinion gears or looking for the stamping on the ring gear that says what ratio it is.
Old Dec 8, 2004 | 04:13 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
for 89-92 all rear disc brake equiped F bodys had the PBR style rear brakes (single piston aluminum calipers with 11.625" rotors)
Old Dec 8, 2004 | 06:22 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
but he said 305 tpi 5-speed (3.45 was very common on those) I guess your rpo build sheet will tell you what it had from day 1
Old Dec 9, 2004 | 01:57 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
3.08s were standard and 3.45s were optional
Old Dec 9, 2004 | 12:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for pics of PBR's:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
BRoss99
Aug 10, 2025 05:08 PM
xkingcodex
Feb 12, 2020 07:43 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
theshackle
Mar 5, 2017 06:37 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
