sorting out 10-bolt reinforements
Old Dec 13, 2004 | 10:19 PM
VILeninDM's Avatar
hey everyone. I am about to make an attempt at making my rear end a little stronger.
I've read that one thing you should do is change the rear cover to something beefier. I've been looking at this item made by AAM. Question I have is that a lot of times you are reading about aluminum cover, a girdle and longer studs (think that's what they are). Does this item have all that, or is it just a cover? Is there anything better?
I can picture how girdle looks and works. What are longer studs? where do they go and what's their function?
Old Dec 13, 2004 | 10:28 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
$99 aint bad!! I wonder how it compares to the TA girdle.
Kevin
Old Dec 14, 2004 | 04:37 AM
ede's Avatar
ede
for a little more you can do better, find one with set screw that go aginst the bearing caps and are locked in place by jam nuts. also some covers have provisions for braces that go to the ends of the axle tubes.
Old Dec 14, 2004 | 05:27 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yah like ede said. Go with a TA it gives some nice support.
Old Dec 14, 2004 | 09:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check the following link for the Summit version:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Dec 14, 2004 | 12:50 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
That SLP part is just a cover. It won't do anything to improve the life of the rearend. You need a TA style girlde like the one pictured above. I buy mine direct from TA Performance. They're Buick guys, but they make a good product anyway : ) They cost a little more than some of the knockoffs, but they were the original, and IMO still the best. I've got one on my Camaro and my Blazer, and installed one on my friend's F150 Lightening.
TA sells a stud kit to replace the carrier cap bolts. These will improve strength and durability too.
Old Dec 14, 2004 | 06:51 PM
VILeninDM's Avatar
thanks guys, now I see the difference. What do you think about moser version moser version of the same thing? With stud kit, it is same price as TA. Reason I am asking is because I also want to order few more parts like axles (I think $240 from them), so I am looking if I can consolidate everything into one order.
Old Dec 15, 2004 | 07:00 AM
In truth I think the Moser girdle is manufactured by TA, and they just stick Moser's name on it. I spoke with a rep from TA that said they do a lot of things like that. He said that if you ordered them in sufficient quantity they would put your name on it if you wanted!
BTW, the Moser axels are great. I'm running a set of 28-spline ones in my car now.
If you are going to do gears I highly recommend Yukon gears from Randy's Ring & Pinion. They are all I've used for the past five years. The quality is first rate, the price is good, and they set up well every time, unlike some cheapie foreign made gears that cost significantly less.
Old Dec 15, 2004 | 08:06 AM
VILeninDM's Avatar
yep. I just bought 4.10 gears and master rebuid kit from randy's. I agree they are good guys. The only thing I don't like about them is the logo.
Looks like I am calling Moser today. I want to make sure I get the stuff next week. This weekend I am starting the rear end. For once I actually got lucky on something and showed up at the company I used to work for at the right time. They are moving to a smaller office and I bought 2 workbenches for $15 bucks a pop. I am bringing them to home on friday. (yeah, I had to share that ) I'll be putting them to good use.
InfernalVortex
Apr 20, 2021 11:31 AM
db057
Jan 10, 2020 08:55 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Fronzizzle
Sep 8, 2015 12:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
