Ford 9 Inch Rearend
Ford 9 Inch Rearend
i know a lot of guys have referred me to converting to one of these...and now i'm considering it....however i don't know much about it....so could someone please tell me what is all involved in doing this? do i have to just swap in a center section and axles, or do i need to take a whole 9 inch and get it down to fit a 3rd gen....what exactly has to be done....
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Ford 9 Inch Rearend
If you cant locate them anywhere, you might want to buy a junk f-body rear, ( if funds permit) from a V-6 vehicle. A non posi rear will probably be less expensive, since you only need the perches and brackets anyway...
so all i need is a 9 inch housing, then cut my 10 bolt section out, and replace it with the 9 inch housing....then just buy a ford 9" center section, and put it in, right?? and then get shorter axles...
NO, you can remove the brackets, and spring perches, and weld them onto the 9 in. housing. Doing it this way will almost cost as much as a unit already built from Currie or Moser. The housing that you are to use has to fit the f-body chassis, you might have to remove material from the axle tubes to fit it. Then there is the axles, brake issues etc. If the rear was not in a 3rd gen f-body, this can be a costly conversion. My 9in. was built by Currie with all the goodies, and I also had the housing powdercoated black. All I had to do, was, send them my disc brake brackets, and the NHRA legal metric (longer) wheelstuds, and for about $2400.00 my new rear arrived. A friend of mine built a non f-body 9in. from scratch, and I think all he saved was a couple hundred dollars, and he had no powdercoating. ...Tom
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
If you shop around you can get a bolt in 9" housing for around $500 brand new. That's the best way to go. If you check swap meets you'll probably find one even cheaper.
Unless you're a good welder, and have experience setting up a chassis and modifying rear ends the best option is to just buy a professionally built housing. To convert a 9" from a Ford vehicle you will have to cut off the spring perches, fabricate and weld on spring perches, LCA mounts, a panhard mount, and a TA mount. You may also have to narrow the rear if it is too wide. None of these tasks should be undertaken by anyone who isn't familiar with them. Failure of a weld could have serious consequences at worst, at best you wind up with a rear end that is junk because the suspension geometry is wrong. This isn't a minor undertaking; it's major surgery.
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
What he said
LT1Formula
Oct 8, 2015 08:34 PM
