Sounds like rearend is bout to give out, 9inch ford?
Old Dec 21, 2004 | 03:56 PM
/\/3\/\/l8l3's Avatar
Well I got on her today and heard a whine, and it did not feel like I got the traction I normally do, I put her on my new jack (yah!) and posi looked fine, but there were metal shavings Bah it lasted longer than I ever expected but I know my time with my rear end is limited (haha)
I'm needing a rearend able to withstand lots of abuse, lets just say I may enter the realm of 700hp within the next year (if I keep it that long) and just curious if anyone can recommend me a bullet proof rear.
Old Dec 21, 2004 | 04:05 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
for thar power level, id get a 12 bolt.
9" rears need more power to turn ...
Old Dec 21, 2004 | 07:04 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Why not buy the strongest rear you can get since there priced about the same. And about that more power to turn thing does anyone have any numbers to back that up? because from what I heard from a few guys that dynoed there cars they only lose about 5 hp swaping to 9" rears from there 10 bolts.
Old Dec 21, 2004 | 07:37 PM
Spectre's Avatar
Engine: 3.0L/183
Id try and keep it all chevy if its worth anything ..
http://www.moserengineering.com/mose...s.asp?CatID=28
Old Dec 21, 2004 | 07:39 PM
I have talked to several established bracket racers and they say that dana 60/ford 9inch take 5% more power to turn than a stock 10bolt. But then again this was their opinion. 5% isn't really that much of a loss being this rear end needs to last me till I get rid of it.
Old Dec 21, 2004 | 08:47 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you are going to go the aftermarket 9" ford route why not consider a 12 bolt from moser or strange? They will cost you about the same when it is all said and done.
Old Sep 14, 2005 | 04:48 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
WOW!!! 5% that kinda sucks that is like a 20 hp loss with 400 horse.
Old Sep 14, 2005 | 07:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Percentage losses are never accurate. It takes a fixed amount of HP to turn the diff or tranny.
20 hp loss with 400 hp. That means my 830 hp engine would lose 41.5 hp going through the same diff. I don't think so.
Parasitic driveline lose is fixed. The 10 bolt doesn't take a lot of HP to turn. The 9" and 12 bolt take a little bit more but on a high HP car, you'll never notice the difference between the 2 of them.
Since they're both roughly the same price, buy what you like. In cars like Stock Eliminator, they have to use the 12 bolt because they're not allowed to put a Ford diff under a GM.
The nice thing about the 9" is that there's only one carrier required. You buy a posi in the spline count of whatever axles you want to use then you can change your gear ratios onto the same carrier. Put some 2.50 gears for high speed highway driving or 6.50+ gears for rock crawling. There's no multi series carriers required for the gear swaps.
Old Sep 14, 2005 | 08:57 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Having only one carrier is a great benefit if you live in a place with an 1/8-mile racetrack and lots of open roads for high-speed driving, such as Kingman, AZ. Thirty minutes, then Wam! Back on the highway.
Old Sep 15, 2005 | 03:06 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm new to the 9", would someone miond telling me what has to be done to have a second carrier set up for like 3.40 to compliment my current 4.11's? An idea on what parts are necessary, approx. costs, what you have to do to change them out, etc. would be real mice.....
Old Sep 15, 2005 | 03:15 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Speaking of mice, did you know three mice are missing from a NJ biochemical test lab that have the bubonic plague?
What do you mean by second carrier setup. You get another set of gears and install them. Takes about 30 minutes. They dont cost much. I'm guessing 200 dollars maybe less. You keep one set of gears for racing and one for street driving. Although, I have told others before that our 95Z28 has 4.10's and we have no problem with them on the highway.
Old Sep 15, 2005 | 03:17 PM
82knightrider's Avatar
Transmission: TH200C....700R4
thats some scary Schit
Old Sep 15, 2005 | 03:20 PM
vernw's Avatar
OK on the mice.... jeez... rag a guy for his typos why don't ya
Guess I'll have to learn how to pull and install/set-up gear sets....
THe reason is for fuel economy on highway trips. My old 3.42 10-bolt RPMs were noticeably lower at 70MPH than the 4.11's are with my T-5. Your T-56 makes a bit of a difference... LOL
Old Sep 15, 2005 | 03:24 PM
Your right on the T56 thing. Changing gears isn't that difficult really. You can buy video's or books on how to do it. As far as the mice thing goes, I was just passing on pertinent info...
Old Sep 15, 2005 | 03:26 PM
It's true, the story is on yahoo's front home page in the news section..lol
Blue419
Sep 10, 2015 01:03 PM
Fronzizzle
Sep 8, 2015 12:10 PM
rsrookie
Sep 5, 2015 07:08 PM
Jetmeck
Sep 4, 2015 12:29 AM
