Trans stuck in 3rd gear
Old Dec 27, 2004 | 01:36 PM
blue_thunder91's Avatar
Car: 1991 Camaro Z28
Someone help! I have a 91 z28 camaro with a T5 and it seems to be stuck in 3rd gear for some reason??? No other gear will engage, I can move the shifter around without the clutch and it sucks!!! Even when the shifter is in teh neutal position it seems to be in 3rd, I cant go in any other gear and it sucks cause i just finished fully porting and gasket matching my intake(which took alot of hours to do). Any suggestions how to fix!???
Old Dec 30, 2004 | 08:41 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
sounds like the fork is broken, you wont know till you open it
Old Dec 30, 2004 | 11:58 AM
I was wondering if it could be the pressure plate that isnt engaging which would explain why i can't shift to any other gear, right?
Old Dec 30, 2004 | 01:00 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
If you put the shifter in neutral, slide the clutch out, and the car moves, it's definately in a gear. Like 86Z said, might be a broken shift fork. Park the car until you can get someone to look at it. And if it needs to go to a shop, have it towed on a flat bed tow truck.
Old Dec 30, 2004 | 01:33 PM
I'm having the car checked out in a while by a friend who is a mechanic and we will hopefully find out the problem. I'll keep you all updated on what the problem is.........hope its nothing to big cause i was planning on buynig some new 4.11 gears.
Old Dec 31, 2004 | 11:25 AM
This guy came by to take a look at the car and said that it's the where the clutch and flywheel are togther that is the problem. It had the clutch changed not that long ago and he says that they probably just threw it on there and that the flywheel is probably all glazed...............what do you'll think?? He says it cant be anything else.
Old Jan 1, 2005 | 10:49 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
dude.....
can you put the shifter in nuetral? if you do can you rev it up and let the clutch out, does the car move? if so its a tranny problem not a clutch/flywheel
let us know
Old Jan 4, 2005 | 10:43 AM
Actually the car does move when it is in neutral, but its not a tranny problem. We took out the tranny and discovered that the bushing that pushes the clutch/flywheel setup was completely melted and wasnt engaging the clutch. We replaced it and re installed the tranny, and what do you know, that was teh problem. Quick and easy fix thank ***!!!!!!
Old Jan 4, 2005 | 08:47 PM
rjmcgee's Avatar
Ahhhh, thowout bushing, troublesome predecessor to the throwout bearing.
eightsixseven
Dec 16, 2024 01:50 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
