Need help Changing Governor in a 700r4 transmission?
Old Jan 10, 2005 | 06:57 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Does anyone know of a link were they show how to change the Governor in a 700r4 tranny??
Old Jan 14, 2005 | 04:02 AM
Night rider327's Avatar
Car: 1988 Camaro
Round cover on driver's side rear of trans,
Some had a clip over the round cover, some didnt
If it have a wire clip, use a flatblade screw driver to pop the clip off.
The round cover will need to be pop off too. Use a flat blade screw driver between the trans and back of round cover and pry the cover off. You may even need to hit the screw driver with a hammer a few times.
Once cover is off, grab the Governor and twist counter clock wise 1/4 turn will pulling out on it. It will pull right out.
To put it back in, push Governor and turn 1/4 turn clockwise. Put a new big O ring seal on the lip of the cover, wipe alittle trans fulid on the rubber seal, push the cover in the hole by hand, then tap on the cover easy with a hammer till it seats all the way down flush.
If it has the wire clip, pop it back on by placing the top of the clip in the hole on top then snap in place on the bottom
Old Jan 14, 2005 | 07:17 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Night rider327, Thanks alot for the help! i printed out your reply, ill give it a shot as soon as i get the new Governor. Thanks again!!!
Old Jan 14, 2005 | 01:03 PM
Car: 1988 Camaro
DA BRONX... Your welcome, glad I could help
Old Jan 14, 2005 | 08:49 PM
chris718's Avatar
boogie down bronx,cross the triboro and come see us if you need something.5 minutes from hunts point.
Old Jan 15, 2005 | 09:17 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
I would but i have 2 things agians me right now, My car is off the road and i live in long island now.Whats the name of your shop how long have you been their and what street are you on? when i put the car back on the road. illl have to come see you.Thanks later
Old Jan 15, 2005 | 05:41 PM
chris718's Avatar
address on website.
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
formula_novice
Aug 18, 2015 08:48 PM
