How To Tell If I Have A Shiftkit?
Old Jan 12, 2005 | 08:02 PM
klumb15's Avatar
My car shifts pretty firm, way firmer than stock, but I never got to ask the previous owner on what exactly he did to the tranny....is there a way to tell what exactly is done to the trans or no???
Old Jan 12, 2005 | 10:06 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Not without taking the valvebody out and checking it.
Old Jan 13, 2005 | 03:37 PM
klumb15's Avatar
hmmmm....i'm guesin its a transgo kit because when i got the car, it had a bunch of junk in it, including a transgo shift kit box, so i'm assuming thats whats in it...
Old Jan 15, 2005 | 08:04 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I have the same question. I know this isn't the trans that was originally in the car. Shifts seem a lot firmer than any other f-body I've driven.
What exactly do I need to look for to know if the trans has been modified?
Old Jan 15, 2005 | 02:53 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well its not a 100% test since some transmissions do this anyway but none that I have had or driven.
Put the car in 1st gear and take off, drive to 5k and see if it shifts out of first to 2nd still locked in 1st. All shift kits remove the MTV spring and this prevents the trans from shifting to 2nd when locked in first. Some members of this board claim thier stock trans wont shift but I havent seen it with a stock 700R4.
Old Jan 15, 2005 | 04:11 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Think that would work for an '86 model 700r4?
Old Jan 15, 2005 | 04:29 PM
klumb15's Avatar
when i have mine in first, it will never shift outta first, and that goes for the rest of the gears too....so i guess I got a shift kit then....i wonder which kind....
Old Jan 15, 2005 | 05:12 PM
nidyanazo's Avatar
Car: Gutted 92' RS TRACK ONLY / '86 Mustang gt 'vert / 1982 Yamiaha xs400 Cafe Racer
Engine: L03; TBI is IT! / 5.0HO (306) SFI / 400cc air cooled twin
Transmission: 700-r4 / WCT5/ 6-speed close ratio
Ok dudes I can leave it in 1st all day long, spin it up till 5k and let off the gas and it'll stay in 1st. I got the car TOTALLY STOCK from a little australian grandmother. So there's no way it's got a kit. I mean the shifts are firm, but leaves a bit to be desired in terms of lightning quick shifts. The only time it DID shift outta first, I was driving down a super steep, slow, winding hill. I wanted to keep it in first for the added control, but i gassed it on a streight-away and it went to 2nd. I pretty much always used to shift it manually......Maybe inprovments were made in the later years to the 700r4? I've wondered about this for a long time. Maybe TKO or someone can shed some light on this.....
Old Jan 15, 2005 | 05:18 PM
305q_ta86's Avatar
Transmission: 5 spd
Originally posted by nidyanazo
let off the gay
Whaa?
Old Jan 15, 2005 | 05:22 PM
nidyanazo's Avatar
hahahah GAS!
Fixed that. lol
Old Jan 15, 2005 | 06:25 PM
klumb15's Avatar
maybe you do have a kit in it, because usually stock 700r4's don't last long when manual shifting them...they tend to blow out gears prettttty fast....
Old Jan 15, 2005 | 07:38 PM
RaGe's Avatar
Car: 1990 Firebird Formula
I tend to believe that if you bark 2nd gear and your TV cable is adjusted stock then you probably have a valve body kit.
Mines done it since I bought it, and this isn't my first thirdgen.. My transmission also makes the 2-3 shift pretty quick, which is another good sign.
The 700r4 doesn't really shift that bad stock either though.
Old Jan 15, 2005 | 07:47 PM
305q_ta86's Avatar
Transmission: 5 spd
hahahah GAS!
Fixed that. lol
hahah ok I was wondering about that...
I bark 2nd all the time. At only part throttle, too. I thought that might have been a bad sign for a stock tranny, but then again, my car was owned by a mechanic for 6 years before I bought it.. Maybe he did something.
Old Jan 15, 2005 | 08:41 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
LIke I said its not 100% proof positive of a shift kit. Nice quick shifts with a little chirp can come from a bone stock transmission if the TV cable is adjusted a tad the tight side.
Old Jan 15, 2005 | 09:50 PM
RaGe's Avatar
Agreed.
88greyiroc
Dec 13, 2001 11:02 AM
88greyiroc
Dec 10, 2001 07:19 AM
88greyiroc
Dec 8, 2001 09:06 PM
88greyiroc
Dec 8, 2001 05:35 PM
RSpeed
Aftermarket Product Review
Dec 1, 2000 07:30 AM
