T-5 clutch return safety spring switch *late*
Old Jan 16, 2005 | 12:56 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Alright its really late so I'll be brief. My cruise control did not work due to clutch safety switch not getting any return force from the clutch pedal. Is there a spring to hold the clutch against the switch? Right now i taped the switch, however that isn't idea because when I press the clutch the cruise control doesn't disengauge. I do not have a spring but i see where one would ideally fit. If anyone has a picture that would be ideal or could describe the spring more so I could find one, cause now the clutch pedal has a lot of play before it begins doing its job.
Old Jan 16, 2005 | 04:08 AM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
you should be able to adjust the switch if i remember right.
Street Lethal
Apr 30, 2019 12:14 PM
maroe624
Apr 16, 2017 08:29 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
