Need speedometer Gear....... help..!!
Old Jan 22, 2005 | 11:39 AM
Cooter77's Avatar
Car: 89 IROC-Z / 11 2500 Sierra
Engine: 5.7 & Duramax
Hello all..... I am in need of some assistance
I need a 44 Tooth speedometer gear.
I changed my rear end from 2.77 to 3.23 in my 89 IROC 5.7ltr.
(Rear-end out of 91 Z 5.7ltr)
My old gear is Red a 37 tooth.
The dealership are the only people that I can find in MEMPHIS that sell a gear. They tell me the only way I can get it is it I buy the aluminum housing it sits in to and its $45 bux.....!!!!
And I will have to wait 10 days.
And its special order so if its wrong then I still eat it.
I believe the color is "Dark Grey"
If anybody has one, could you send to me COD and i'll even toss you some loot for it.
Old Jan 22, 2005 | 12:23 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I've got a 45 tooth if that'd be close enough for you. How's $10 shipped? PM me if you're interested at all. I know its not your 44 tooth, but it'll be very close. I was going to use it for my 2.73-->3.23 swap but it turns out the rearend I had bought was just a 2.73 anyways. I now have a 3.42 in the garage waiting to go in, so I won't be using this gear at all (never used, bought from GM).
Though, I'm pretty sure you will need that sleeve the dealership is talking about because I think there was a different VSS sleeve when the gears went to 40-toothcount and up.
Old Jan 22, 2005 | 03:12 PM
chris718's Avatar
i stock them new from gm.give me a call monday and ill ship it out.i need tire height in inches so i can have your speedo reading correctly.
Old Feb 3, 2005 | 06:17 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Speedo Gears
Go to www.transmissioncenter.net that is where I got my speedo gears and the aluminum housing to fit it for about 35.00. They have the formulas for figuring what you need. I'm going to a 700R4 in my car with 3.73 gears and a 245r15 tire. Check them out, I think you find what you are looking for.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
