Torque Converter Help
Old Jan 23, 2005 | 01:17 PM
steveiguess's Avatar
Car: 1986 Camaro
Engine: zz4 350 w/mods
Transmission: 700-R4 W/Shift kit
I have a cam in my zz4 motor that has a power range from 2500 to 6000 rpms. I have a stock 1200 stall in it now, and i drive my camaro every day. Currently I am running the 1/8 mile in 8.7 seconds at 83 mph. It peels out pretty nasty, and breaks loose in 2nd. but i am launching it at 1,000. I have purchased slicks, and i want to put a stall in to be able to launch it quciker to drop those 60ft times (2.3) and to get a quciker overall time. Do you think a stall would be a good idea, and what stall speed should i go with. Keep in mind I do drive this car every day.
Old Jan 23, 2005 | 01:52 PM
chris718's Avatar
if you want excellent performance use a 2800 stall 10/12 converter.this thing will only stall this high when powerbraking and will flash to 3000 upon releasing the brake.the use of the lock up clutch will still conserve fuel when cruising at the convertor will act like a stocker untill you put your foot in it.what is the final drive(rear end ratio)?if the engine wont ingest air above 6000 rpms this will give you roughly.3000 rpms in each gear to accellerate the car,perfect for a naturally aspirated engine of that size.lock the converter and your back to factory cruise rpm.this will get the car moving from a dead stop,a huge increase in performance.
Old Jan 23, 2005 | 07:37 PM
Car: 1986 Camaro
i have an eaton posi with 3.73's and a 700 R-4 with a shift kit and a painless wiring overdrive kit (no computer in car). where would I buy the converter you are talking about, and how much $$$?
i was looking at the B&M holeshot 2500, but is your idea of the converter better, in a sense for street driving?
Old Jan 23, 2005 | 07:47 PM
chris718's Avatar
get in touch with me .see url
Old Jan 23, 2005 | 08:12 PM
Car: 1986 Camaro
ok, in your last post you said lock the converter, and you are back to factory crusing speed. Does this mean that you have the lockup on a switch with this converter, cuz the painless thing i have uses vaccumm to lock it in overdrive.
Old Jan 23, 2005 | 08:27 PM
chris718's Avatar
no ,whatever converter clutch scheduling you have will be the same.itll lock under the same conditions as it does now.its just a matter of putting it .i mean that even with the high stall of the torque converter it will be the same as any other when locked up ie no slippage between the crankshaft and input shaft of the transmission.
Old Jan 23, 2005 | 08:31 PM
Car: 1986 Camaro
oh, ok. ya i have this camaro and its fast but i think my launch is killing my et's. so if i get the converter i can brake torque it to 2800 rpms, and when i let off the brake and slam the gas it will jump to 3k? how should i contact you? the phone number on that site?
Old Jan 23, 2005 | 08:53 PM
chris718's Avatar
yes or via email if you like.check out the site too there is some good stuff on it .
Old Jan 23, 2005 | 08:59 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
whatever you do, don't buy any of that b&m junk! just bought an ati converter. paid ALOT for it, but it's the best on the market if you ask me. listen to Chris. he knows what he is talking about. make sure he has all the specs for your motor, then he can get you the optimum stall speed for your specs.
Old Mar 13, 2005 | 10:02 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Why are b/m converters junk? Have you tried them? I'm just asking because I was thinking about geting a holeshot that stalls about 2400.
I'm sure the ATI is better on the street but just wondering if you've had bad experience with b/m which would steer me away from them. thanks.
Old Mar 14, 2005 | 12:57 AM
mw66nova's Avatar
Engine: 7.0L
never wasted my own money on them, but a few of my friends have, and all of those guys ended up tearing them up. and none of them were making gross hp levels either. if you call a place that builds them, and give them the cars specs, they will build one exactly for what the car needs. i installed mine last weekend, and it stalls right at 2400rpm.
seiplentz
Aug 19, 2019 06:02 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
