Broken Shifter?
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Broken Shifter?
Okay I think this is the right forum. I just browke the bolt that goes from bottem of the shifter lever. So I have about 3" of a metal collar that went over the bolt to shift with.
Does anyone know where to get this part from? I REALLY need it ASAP as shifting like this isnt good on my hands.
Also I cant shift fast so I think its not good on the car either
THis is a manual shifter btw stock T-5 tranny, HELP!
Jurrel
Jurrel
Car: `86 SS / `87 SS
It really wouldn't be too tough to make a shifter stick that threaded onto the shifter itself, and took the **** (M16x1.5 thread) but if it's solid metal, it'll be noisier than stock (rubber isolated)
You apparently just broke the stock shifter stick and that's all.
Car: 1984 Firebird
Annd....any ideas where I can get a replacement? All of the local junkyards are bare of manual transmissions, much less the shift stick.
Car: 1984 Firebird
Well I just need that one peice replaced not the entire shifter. Also I understand that you get alog of noise with the aftermarket ones. Don't need more noise
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
if it helps the threads on the bottom of the shifter are 14mmx2.5 i believe. cant you just take the bottom part and take it off, take the broken part and take it to a exhaust shop and have em weld it? itll take not even 2 seconds and they probably wont even charge you for it, any place that has a welder will probably do it for free, itll be just as strong as stock if they run a bead all the way around. like i said should only take like 2 seconds and itll cost next to nothin if not free. its worth a shot.
Car: 1984 Firebird
Well here are pics of the thing, And I jus found out that 83-84 were the ONLY years to use this shifter according to GM. And with allthe rubber inside, i donno how well they could weld it back togther.
Does ANYONE have one they would be able/willing to part with?
Okay they are now welded togther, but its a crap job...So for the T-5 whats the shifter recommended?
Car: 1984 Firebird
Heh I did, you say hurst, well is there a specific hurst thats better then others?
Ya Im lazy Jus want to call summit, dont want to go looking for anything but a known good easy working shifter
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
no green
Jan 9, 2016 09:22 PM
