th350 governor
Old Feb 11, 2005 | 09:37 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
th350 governor
What happens if you take it out or disable it? I seen in a thread that it wont upshift is that just in drive ,?will it shift manually
Old Feb 11, 2005 | 09:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It won't shift at all.
Old Feb 12, 2005 | 07:33 PM
chris718's Avatar
the governor generates a variable rate hydraulic signal to inform the valve body of road speed and introduce upshifts or ratio changes.without it modulator pressure directed to the shift valves and the influence of the spring tension of the shift valve springs on the shift valves which keep the valves held in the downshifted position against governer pressure will not allow upshifts.if the governor circuit is held wide open the signal will be so high that itll take off in third gear unless it is manually shifted.this is basically how a full manual valve body is made more or less.
Old Feb 12, 2005 | 07:55 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
QUOTE;
how would I make it stay wide open?
And would this hurt the trans ?
this is not street driven
Old Feb 12, 2005 | 08:03 PM
chris718's Avatar
remove the governor ,plug the two holes that feed it oil and then crossdrill line pressure into the governer upshift circuit.it wont hurt the trans,and there is a few other things you can do to firm it up.
Old Feb 12, 2005 | 08:14 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
QUOTE;
Can you explain? my vocab.About tranny's suck
Old Feb 12, 2005 | 08:28 PM
chris718's Avatar
im describing the modifications done to the valve body .after identifying the correct passageways in the casting you drill thru the partition to connect them.you plug the oil sent to the governor to be governed and plug the governer upshift oil passage at the governor port exit so the line oil you crossdrilled intop the circuit doesnt bleed off.if you are not familiar with a transmission get a manual with the hydraulic diagrams or dont attempt it at all.
Old Feb 12, 2005 | 08:52 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
I got a manual. Thaks for the info.
Is there anything else I need to do or know to do this?
THANKS AGAIN
Old Feb 13, 2005 | 09:39 AM
chris718's Avatar
yes if the car takes off in 2nd gear with the selector in manual lo you will need a heavier 1/2 shift valve spring.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
HikoriYami
Sep 21, 2015 07:11 PM
romcjr
Sep 17, 2015 05:18 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
