T56 Swap Questions to those who have done it...
Car: 1992 Camaro RS
Transmission: T56/B&M/Ls7
I looked in the swap thread but i have some more specific questions.
1) Did you guys use the 4'th or 3'rd gen gas pedal..They say you can just cut the 4'th gen gas pedal off the assembly and use the rest.
2) Can anyone explain to me the difference between the master cylinder and the slave cylinder and how to mount them, and also do i need to get a fluid resevior for the master cylinder?
3) I know it the thread it says to align the clutch disk but how do you actually do that on a stock t56 clutch and pressure plate?
4) If I have a complete ECU and trans wiring harness out of a 94z28, will my wiring be the same as described in the thread? or can i just change out my ECU since I've converted to a carbed 355ci anyways?
5)How long did it take you all?
Any help and especially close up pictures would be greatly appreciated.
Thanks to all,
25thredrs
Thanks to all,
25thredrs
Car: 4
Engine: 6
Transmission: 5
1. I used the stock gas pedal for my car (83); and the stock clutch & brake pedals I have in the car (not 83 stock... I think they were out of a 84, but it's been so long since I put them there, probably in 86 or so, I don't recall for sure) ... seems to do just fine, doesn't seem to me worthwhile to do extra unnecessary work (dirty 4-letter word!!) just to swap stuff out that doesn't need it.
2. The master cyl attaches to the firewall and the pedal pushes on it; the slave cyl attaches to the bell housing and pushes on the clutch fork. If you do the sensible thing and go to GM and buy the assembly, you'll get a slave cyl, master cyl, and reservoir; pre-filled with fluid. Pretty much takes the guesswork out of it.
3. Same as any other clutch disc .... with a clutch disc alignment tool. Looks about like a broom handle with splines. You can get one at about any parts store for less than $10, they even come in some clutch kits.
4. ¿ECU? What does that have to do with a transmission?
5. It took me most of a Saturday and part of a Sunday.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
used my t-5 pedals too.
not long, few hours.
but, I had the t-5 already.
if this is all new to you plan a few days, if you know your way around the car and have done clutch jobs before. I would say a afternoon if you have all the parts (this is how long it took to put in the t-5 when I switched to a manual)
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
what type of clutch are you guys running in your T56
HEY RB do you like the duel friction disc. i had it in mine but it just wasnt grabbing good enought
1992 Trans Am
Aug 8, 2015 08:16 PM
