what's really needed in a 700r4 build-up?
Old Feb 17, 2005 | 01:08 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
what all should i upgrade on my 700r4- besides a shift kit, servo, and converter. i am pretty sure i am going to use a full manual valve body. but what else on the inside of the tranny needs to be replaced? assuming the engine is 388 cubes and around 500hp and no nitrous?
Old Feb 17, 2005 | 04:21 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
www.transmissioncenter.net
You might look at some of their offerings for the 700R4... Just so you can learn what's in there...
What year 700R4 are you starting with?
Old Feb 18, 2005 | 02:52 AM
Pro Built Automatics's Avatar
Go to http://www.700r4l60e.com/store/custo...&cat=19&page=1 this should give what you want. Let me know if I can be of help?
Old Feb 18, 2005 | 07:09 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
i was looking at the kits that the probuilt guy has- seems like a pretty good deal. i have never gotten into a tranny before. is it something that i could do myself if i went out and bought some sort of book? i built my engine and rear end just fine- but i am not sure i can do a tranny? are there any special tools i would need?
Old Feb 18, 2005 | 07:10 AM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
Old Feb 18, 2005 | 07:49 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I bought Paul Zank's 700R4 video - http://www.technicalvideos.com/video...smission.phtml
$30 + shipping. I'm also gonna buy a book on the 700.
Old Feb 18, 2005 | 01:06 PM
The ATSG rebuild books are pretty good, about $17.50 each.
Old Feb 18, 2005 | 01:10 PM
TPIs-10's Avatar
Car: 88 S-Dime
Engine: 388
i think i may do some more research and buy one of those books/video's- i don't really wanna spend another grand having the tranny put together- i am already stretching my budget w/o even getting into the tranny- but after reading- i dont know how long a stock rebuilt tranny (like i have)- will last a very long time with the engine i have
Old Feb 18, 2005 | 06:07 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
to make a bulletproof 700r4, go to tci. get the 5 pinion carrier, stronger sunshell, heavy duty band, heavy duty clutches and 9 clutch third gear clutch pack. they also make a servo kit with heavier springs for the second and fourth gear apply piston. also you'll need to get the B&M transpack.
Old Feb 20, 2005 | 01:18 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I am wanting to build up my 700-R4 for more power handling as well, but I find myself working with a smaller budget. So basically I was looking at the Trans-Go shift kit (heard it was far better than the B&M kit) and a billet servo from TCI. Along with of course the fluid and filter change. The only problem is, is that the Transmission has 115,000 miles on it and as far as I know, has never had a fluid or filter change. Now, the fluid is NOT burnt looking or smelling, but still. Can I do these modifications without damaging the Trans?
Thanks,
Max
Old Feb 20, 2005 | 01:52 PM
Demon355's Avatar
I'm in the same boat as myvmax1. Except my 700R4 has about 200km on it. Shifts fine as I have driven my car a few times since I bought it but with this weather it's hard to get it out there and see what could be swapped out or fixed. I was thinking about the Trans-Go kit. How hard would it be to install myself? How much are corvette servo's and where can I get one? With a mild budget, what would you guys also suggest me getting? I might be throwing a 355cu. 390+Hp motor in there and don't want my tranny to be spitting pieces...
Old Feb 20, 2005 | 03:07 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
the amount of mileage you have on your tranny is not going to be a problem as long as it is in good working order. the transgo kit is a bit more involved then the B&M kit. i would not advise doing either yourself unless you are 100% sure of what you are doing. Also there is a snap ring for i believe the second gear accumulator that is very tricky to remove.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
Leggman1
Aug 6, 2015 04:15 AM
