Will a 4th gen rear hold my 500hp 383?
Old Feb 23, 2005 | 10:13 PM
DigitalMonarch0's Avatar
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Hey all,
Simple question here...
Will a 1993 Firebird stock 10-bolt rear hold up to the beating of a 383 stroker pushing approx 500HP?
I got one that I can have for $200... but is it worth it??
Old Feb 23, 2005 | 10:16 PM
yuel's Avatar
Car: 91 z28
Transmission: 4l60
not a chance stock or even beefed up, unless your really lightfoot on the pedal, use that money on a good 12 bolt
Old Feb 23, 2005 | 11:41 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
i agree. 500 hp is a bit much even for a very beefed up 10 bolt, nevermind a stock one.
Old Feb 23, 2005 | 11:44 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you use street tires, they will break loose long before the rear will come apart, so it might have a chance.
With slicks? No &*!%$%@* way its gonna survive
Old Feb 23, 2005 | 11:49 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
actualy, i saw a guy with an iroc running 11.80's on the stock rear with regular tires break an axle at the 60 foot. it wasn't too cool
Old Feb 24, 2005 | 06:26 AM
Engine: 5.0L TPI
Axle/Gears: 3.08
Okay, that's a big help. I'll call the guy today and tell him that I changed my mind. I have a set of ZR1 wheels with drag tires going on in the spring so I see now that it won't work.
If I buy a set of Moser Axils from summit or jegs, will the stock gear-housing hold?
I want to buy a set of 3.73's and posi, so if I kept the stock 10-bolt it would be the only stock piece. Am I okay with my stock unit or should I consider finding a new/used 12 bolt?
Old Feb 24, 2005 | 07:48 AM
FatherFrank's Avatar
Car: '90 Firebird
Engine: 383
If I remember correctly, the axles aren't the weakest part of the rear end (although the 26 splined ones won't last long) but rather our dinky 7.5 ring setup. So, no, buying new ring and pinon gears and a posi won't save the rear. They are just not very strong rears, and 500 hp is usually out of their league.
Go 12 bolt shopping.
Old Feb 24, 2005 | 08:04 AM
ede's Avatar
ede
sure it will hold up, depending on how you apply the power and what you do to enhance it's chances of survival.
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
It might last awhile with your automatic but a stick would destroy it quickly.
Old Feb 24, 2005 | 02:29 PM
Engine: 5.0L TPI
Axle/Gears: 3.08
Well I'd like to be able to rag on it enough to keep me happy. Take it to the track a couple times a month with the drag radials and run it.
So just look for a 12 bolt then?
Old Feb 24, 2005 | 03:35 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
yes, a 12 bolt would be your safest bet. 500 hp and a 10 bolt is like playing with fire. sure, it would hold together for a little while, but with the 12 bolt, you wouldn't have to worry about it every time you put your foot into it.
Old Feb 24, 2005 | 05:07 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I don't see why everyone says that 10 bolts don't hold up. The only reason I see that one would tear up is if it's worn out and the clearances are not right anymore. I hear about these so called weak 10 bolts at the track running 11's and 12's all the time with slicks on spray. Me being one of them. I have a 406 with a 125 shot right off the line with slicks running 6.90's in the 1/8th. This equates to about a 10.80 or so in the 1/4. The 60' times are low 1.6's. The rear was put together about 4 years ago with an Auburn posi and Richmond 3.73's. The axles have 28 splines and are stock. I am planning on a set of mosers though. It's just a junkyard rear from an 89 third gen. My engine has more than 500 hp and have had nothing but good luck with it. There is hope with your 383 and the 4th gen rear. Just freshen it up and it'll hold. Also, I have a 94 6speed with 144,000 miles on that I use ET streets on. I have dumped the clutch right off the rev limiter before and it doesn't spin a bit. Just takes off and goes. I use N2O on this car also. If these rears were so weak it would break for sure. Bottom line is build it and you'll be fine unless you have lots of extra money then get a 12 bolt. My 2 cents worth.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
