Shift kit problems?
Old Mar 2, 2005 | 11:18 PM
808RS's Avatar
Car: 91 RS
Engine: 305TBI
Shift kit problems?
i just put in the transgo shift kit in and the shifts are improved but the 1-2 is only moderate as is the 2-3 how firm is it supposed to be should i be able to chirp 1-2 everytime?
Old Mar 3, 2005 | 06:29 PM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
When you drop the pan, there is a round housing with three bolts holding it in place. Take out the three bolts and lower the housing. There is a spring that sits on the bottom, add one of the large washers that comes with the kit and put the tranny back together. Take the car for a drive, if you still want it to shift harder, add another washer under the spring. It's been a couple of years since I put a shift kit in my car so I don't remember what the housing is called. With two washers, I was able to chirp the tires on the 2-3 shift as well as the 1-2 shift. I kept just one washer in, tho. Hope that helps you out.
ace16a's Avatar
Engine: 5.0 TPI
Old Mar 4, 2005 | 07:16 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I just got my transgo kit last night and thought the instructions said LESS washers for a harder shift?? I could be wrong, but might want to double check or call transgo.
Old Mar 4, 2005 | 08:28 AM
ace16a's Avatar
Engine: 5.0 TPI
mdricken could be right. Like I said, it's been a couple of years since i did mine so i don't remember everything. i do know that i only needed one washer to make the 1-2 shift spin the tires.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
g.l.mos
Aug 22, 2015 12:02 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
