t56 specs - for diff years
Old Mar 3, 2005 | 08:00 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
I know its on this website somewhere.. lol.. somehow i can't find it in any search..
For the different years of fbodies with t56.. what are the specs on gear ratios and designed torque limits? IE what is the best t56 to buy.. more importantly where does the '97 t-56 rate?
thanks..
PS i know this info is probably on here 50 times.dammed if i can find it . perhaps make this a sticky on here?
Old Mar 3, 2005 | 08:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
94-97 are the same, and are the ones to get.
93 is the one to avoid in most cases.
Old Mar 4, 2005 | 12:51 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
harder. I just posted this yesterday.
https://www.thirdgen.org/techbb2/sho...hreadid=281778
Old Mar 6, 2005 | 12:38 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
thanks.. lol i was looking for t56 specs .. but thanks.
Old Mar 6, 2005 | 12:45 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
in case anyone searchs.
T56 Specs t-56 specs
T56 Stats t-56 stats
T56 gear t-56 gear
Thanks to TheGreatJ
Ratios and such:
trans............1st....2nd.....3rd.....4th....5th.....6th.....R.....TQ rating
'93 M28........3.36...2.07...1.35...1.00...0.80...0.62...3.28.....350ftlb
'93 M29........2.97...2.07...1.43...1.00...0.80...0.62...3.28.....400ftlb
'94-'97 MN6...2.66...1.78...1.30...1.00...0.74...0.50...3.28.....450ftlb
700-R4.........3.06...1.63...1.00...0.70......................???......????
The "double overdrive" means 6th gear is an extremely high gearing. This means low highway RPMs even with a very deep rearend. I run 3.70s in the back and turn about 1800 at 80mph on the MN6 tranny. This in turn is a big gas mileage boost if you spend any time on the highway.
Old Mar 6, 2005 | 11:29 PM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
What prices are good to look for in yards? I wanna see if i can fing a 97+.. i just hope i can find a yard that doesnt know how much it is worth... and isnt trying to screw me with a **** tranny...lol
Rabbitt
Old Mar 6, 2005 | 11:45 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
a 97+ F-body T-56 would be for an LS1. I believe all but one bellhousing bolt would mate up, plus a few other differences you can read below.
Old Mar 6, 2005 | 11:57 PM
TheGreatJ's Avatar
'97 is still an LT1 style tranny, and will work fine. '98+ is the LS1 style, which has a different bellhousing, adapter plate, input shaft, etc. The LS1 tranny can be made to work from what I hear, but it's probably a lot more trouble than it's worth. Just stick with the '97 and older tranny....they're proven to work very well.
Old Mar 7, 2005 | 06:53 AM
CrazyHawaiian's Avatar
Car: too many ...
If you can afford to wait, then I'd wait it out for a good deal. I agree the 94-97's are the best ones to get. I see them on ebay for around $1300-$1500 + a core charge fresh rebuild. I dont come across them at the yards here locally, very rare, so not sure on yard prices. In all honesty, I'm one of those guys that prefers a built T5 because its cheaper in the long run (considering the parts needed for a T56 swap). So I didnt really actively go after any T56 deals, but I did wait it out and a good deal found me. I decided to go for it, so I'll be converting my 91 Z28 to T56 soon. A friend decided to part with all his 3rd gen stuff which included a '94 T56 with 40k miles, OEM flywheel/bellhousing/master slave cylinder/clutch/brake pedal assembly, then the spohn crossmember and torque arm 3rd gen conversion kit, and the Mcleod pressureplate/clutch disc set. Complete crazyness. Really cheap too, under $1000. I'm also thinking about going with an aluminum flywheel.
Old Mar 7, 2005 | 07:34 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
lol, thats the kinda deal i would love to get! lol, otherwise, it will be next year.. i'll just NOT spend the money on a shift kit or new torque converter for the r4..... cause i want the t56 really bad... for manual and for the double overdrive..
Rabbitt
AussiePr0nCar
Mar 6, 2020 04:04 PM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
jharrison5
Aug 19, 2015 05:53 PM
