Need Help- LSD!
Old Mar 4, 2005 | 01:19 PM
warheart's Avatar
Car: `84 Trans Am, `78 Monte Carlo
Engine: 350 TPI, 454
Transmission: T5, TH350
Axle/Gears: 3.23, 3.42 posi
Need Help- LSD!
Well i have GM 10 bolt 7.5 limited slip axle it has 2.41 gears (measured by myself and i´m positive). RPO is GU1 and axle code is 2BZ. Can i throw 3.73 gears in with this LSD?
Marty
Old Mar 4, 2005 | 01:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Only if you use a spacer, or the "special" gears. I wouldn't recommend using those gears though.
Old Mar 4, 2005 | 01:34 PM
warheart's Avatar
Why you wouldn't recommend??? Where i can get the spacer and how much it would go?
Old Mar 4, 2005 | 02:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Because if you use them, you're stuck from that day forward, forever, with a 2-series posi. In order to put in a 3-series posi you'd have to re-replace the gears.
If you use a spacer, and some day later you come up with a 3-series posi, all you do is take out the spacer and you're good to go.
It's not an issue of strength or whatever; it just is a question of sealing yourself off from future options.
Cost is virtually the same either way.
http://www.drivetrainspecialists.com...s.php?catid=73 Do a search on the page for "spacer".
Old Mar 4, 2005 | 03:25 PM
warheart's Avatar
Thanks RB83L69
Bigold4x4
Sep 28, 2015 05:21 PM
miacamaro305
Apr 19, 2005 09:13 AM
xtremeirocz
Mar 30, 2005 03:15 PM
StealthElephant
Oct 1, 2003 11:46 PM
ninety1TAgta
Oct 14, 2002 08:56 AM
