9bolt axle shaft ??????????
Old Mar 9, 2005 | 07:55 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
Is there a differance between 88 disc braked 9bolt axle shafts and 89 pbr braked axle shafts. I have an 89 9bolt with pbr's and my driverside axle shaft is bent. I found some one with an 88 9bolt axle shaft that has the cast iron brakes. Are they differant length's. The 89 9bolt shafts have a pbr brake brakcet as part of the bear stack up, is this the same with the 88 9bolt. Any info would be great as i'm trying to get my daily driver back running.
Old Mar 9, 2005 | 07:59 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are the same. The brakes don't make any difference to the axles.
The 88 will have the Saginaw backing plate, rather than the PBR one. The Saginaw plate will not work with your PBR calipers. Just use your existing backing plates when you put it back together.
Old Mar 9, 2005 | 08:04 AM
doc76239's Avatar
Engine: TPI 305
RB83L69 you have a pm.
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
6998poncho
Sep 25, 2015 02:56 PM
dbrochard
Sep 7, 2015 09:41 AM
