gear swap
Old Mar 13, 2005 | 03:29 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
gear swap
hey i was wondering if anyone could help me with some rear gear stuff.
right now i have a carb 305, 700R, and 2.73 gears. Needless to say i can probably beat my car on foot in a 60 foot race.
i need to kno what is involved in swiching gears, which is something i kno nothing about. do you have to change the whole axle or can you just throw new gears in the existing one. Also, how do you get the spedo back on, ive heard of it being easy on a standard shift tranny, but im not sure about autos.
Finally, whats a good car to look for in the 'yard that i can steal gears from, im looking for like 3.23s or so...ive heard blazers but i really want posi lock
any help is much appreciated...thanx
Old Mar 13, 2005 | 05:48 PM
ede's Avatar
ede
you can swap gears or the entire rear. if you've never done gears go for the rear swap. any 3rd or 4th gen rear will be a direct bolt in, the 4th area a few inches wider.
Old Mar 13, 2005 | 07:24 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
if u havent swapped rear end gears before then i would not attempt it i would spend the extra cash to have some one with some know how do the job or just help u install them... my car was down for 2 days because i didnt have the correct bearing splitter for the pinion gear but i did get the mesh correct with out all the exspensive tools that every one else has... no gear whine at all
1984HO
Mar 19, 2021 11:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
