i need help slave cylinder
Old Mar 15, 2005 | 07:22 PM
q8irock's Avatar
Car: camaro iroc z 1986
Engine: LT 1
hi there this is my first post and i need help
i just swap a t-56 in my 86 iroc but the slave cylinder wont fit in the bilhousing and i dont now how to fill and bleed the master and slave cylinder and this is the first time i work with manual transmission .
i am in kuwait and i am the first here how do the lt1 and t-56 swap so its very hard and thank for you all how post her because without you i cant do any thing and forgive for spiling
Old Mar 15, 2005 | 08:38 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Axle/Gears: 3.23 posi
OK, what bellhousing are you using? Does the car have the original '86 V8 motor? You will do this just fine--have patience.
Old Mar 16, 2005 | 05:45 PM
q8irock's Avatar
Engine: LT 1
i have lt1 engen and t-56 orginal belhousing but the rod in the center of te slave cylinder is to long so i cant bolt the slave to the belhousing i need to now how to bush this rod in the cylinderand thanks for the reply
Old Mar 16, 2005 | 06:50 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
You need a lt1 bellhousing . It includes a spacer for the slave setup.
Old Mar 16, 2005 | 08:02 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
q8iroc--listen to Pasky. The T56 does not fit the early V8 bellhousing you have. You need the LT1 bellhousing or a Weir bellhousing.
Is your T56 bolting up to your bellhousing? Is the only problem the slave cylinder? Then you already have an LT 1 bellhousing and this can be worked out. Many people on this site know much more than me about this--it will work out.
Old Mar 17, 2005 | 03:30 AM
q8irock's Avatar
Engine: LT 1
its lt1 belhousing (the rod in the center of te slave cylinder is full out so i cant bolt the slave to the belhousing i need to now how to bush this rod in the cylinder)and i have the spaser
Old Mar 17, 2005 | 12:38 PM
pasky's Avatar
Ok, just pu the spacer on the bellhousing, make sure the clutch fork is grabbing the yoke (throw out bearing). The way to check if its seated on the throw out bearing correctly is to push it forward, if it falls lower, its not on right and you will bend your cylinders. Just ask me how I know =/ Seat it correct and put the slave cylinder on and just push it against the fork, the pushrod on the slave will compress and get the two nuts on the studs and tighten it up. Test your work after everything is tightened by sitting in the car and pressing the clutch pedal. If everything is okay, it will push to the floor without any resistance. If you find the pedal is extremely hard to push DO NOT FORCE IT TO THE FLOOR. The fork has moved and is out of position if this is the case. If you force it you will bend your master cylinder's pushrod. Just ask me how I know .
Old Mar 20, 2005 | 03:52 PM
q8irock's Avatar
Engine: LT 1
thank you all
its don
thanks
Old Mar 22, 2005 | 10:35 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
q8irock--so, do you have a picture of your car?
Old Mar 23, 2005 | 11:21 AM
q8irock's Avatar
Engine: LT 1
i dont have the trans bics but this is the engen in the car i just test it today and its wonderfull .. i have got 4th gen befor 1995 z-28 but this is my first t-56 car i have got also 1972 z-28 with manual trany i think it was t-10
Old Mar 23, 2005 | 11:23 AM
q8irock's Avatar
Engine: LT 1
sorry this is the bics
and this link for my car pics befor the swap
http://www.q8hp.com/camaro_14.htm
and this for my 1972 z-28 after i sell it
http://www.q8hp.com/camaro_7.htm
and this befor i sell it
Old Mar 24, 2005 | 09:56 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
Excellent--thank you. My fotos are too big to attach to this site; I haven't figured out how to reduce them but I have several cars. You are obviously a Camaro dude. Congradulations on the T56 swap
Old Mar 26, 2005 | 11:43 AM
q8irock's Avatar
Engine: LT 1
thank you rbjones
and you can reduce your fotos in any imaging sofwer by resizing them you can use (acdc) or (adobe photo shob) or (uled photo expres) and so
and if you dont mind to send them to my e-mail
( if you dont mind)
my e mail is ( z28@hotrodq8.com )
or (q872z28@hotmail.com)
thanks
Old Mar 27, 2005 | 12:42 PM
rbjones's Avatar
Car: '82 Camaro
Transmission: wc T5
q8iroc--thanks for your help. I'll send pics of my '82 Camaro and my '60 Austin Healey with a Chevy motor to your e-mail.
Old Mar 30, 2005 | 04:34 AM
q8irock's Avatar
Engine: LT 1
thanks rbjones for the photos and if any 1 have photo and can post them because i want to paint my car and i want to se it in defrent color and hoods to figor the look of the car bofor i do any thing
thanks
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
