Is this, or is this not a locker. Important
Old Mar 16, 2005 | 10:34 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Okay, along with my new engine, i got what I was told was an Auburn Locker w/ 3.23's.....wonderful, i need the $$ badly so i'll sell it. My friend looked at it and thought it looked wierd, i called the guy back up and double checked, he assured us it is a locker.....my friend still disagrees. I have no idea who's right, i trust my friend way more than the guy i bought it from (that guy was sorta STRANGE), but i'd like some more opinions. Is this, or is this not a locker.
Thanks,
-Chris
Old Mar 17, 2005 | 02:57 AM
Night rider327's Avatar
Car: 1988 Camaro
It aint a locker thats for sure. Looks like a std. open (non posi) carrier setup to me.
Here's a pic of my locker installed... http://community.webshots.com/photo/...89814258GTAYZu
and here's the locker parts out of the box before I installed it...
http://community.webshots.com/photo/...89812757GOxSrg
A limit slip unit (AKA posi) uses clutchs, and/or springs, to apply both wheels, it gives the wheel with the least amount of traction, the most torque. I don't see no clutchs in that one. It could be some style of newer limit slip unit, but I aint sure cause i'm use to the old types. But I know it aint a locker, and really I don't even think its a posi unit
A locker is a mech. "gear drive" that has 4 main parts, that replace the spider and side gears. Those parts has teeth made onto them, and the locker pushes together and teeth lock, so you get a fully locked rear end when under heavy load. It puts the same amount of torque to both wheels
Old Mar 17, 2005 | 06:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, that's yerbasic "open" one-wheel-peeler.
Here's what an Auburn looks like. That isn't one obviuosly. Or, it's missing some parts.
I hope you didn't pay money for that, as if it was some kind of special thing or other; if you did, somebody ripped you off.
Attached Thumbnails Is this, or is this not a locker. Important-c-old-d-drive
Old Mar 17, 2005 | 12:08 PM
meh, i bought my new engine with a bunch of stuff and that was one of the things...
its 3.23's, is it worth anything at all?
Also, where can i get an inexpensive posi?
Thx
Old Mar 17, 2005 | 02:04 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thx
Only if you have a 10 bolt 2.73 ratio in your car now and this came with the pinion gear and the axles.
SLP if you can still get them other then that I'm partial to the power trax.
Old Mar 17, 2005 | 07:20 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Looks like an Auburn Gear limited slip diff. to me (NOT a locker), but it's missing the springs and plates that go between the side gears. This unit uses cones instead of clutches.
Old Mar 17, 2005 | 07:32 PM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
Just do a search for the casting numbers on the diff. They should be right near that orange paint spot somewhere.
Old Mar 17, 2005 | 08:27 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
im the friend that told him it wasnt a locker. I looked through teh thing and i dont even see the cones that are in it. ibe also heard those cone one suck. I was gonan buy it off him if it had actually been a locker. the guy swears up and down when he had it in his car it spun both tires.
Old Mar 17, 2005 | 09:32 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
It might have spun both tires if they were off the ground.
That's an open diff. It's basically worthless, unless you have one that needs replaced and you're too broke to buy a posi.
TheGreatJ's Avatar
Oops...double post.
Old Mar 17, 2005 | 09:35 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Has any body welded the spider gears together? kinda ******* and a risk of breaking the axles.
Old Mar 17, 2005 | 09:36 PM
R-E-D--N-E-C-K-
it (*) that out?
Old Mar 17, 2005 | 11:16 PM
Car: 1988 Camaro
Yeah, I bet it will spin em both, probly even lay 2 marks down.. They won't be even, same lenght or color, but it will be 2 marks. A limit slip and locker will lay em down the same lenght, and color
The reason why it will lay down 2 marks is....
when you do ALOT of 1 wheel burn outs you wear the parts hard. When an open rear wears, the point of wear from burn outs is the spider and side gears, along with the crossshaft. I was showing somebody those pics today, and was telling them about the wear on the cross shaft in that pic.
In the 1st pic to the left, look at the mark on the crossshaft down close to the bottom. The shaft should be clean, smooth, and not a spot on it. That one aint. It's worn.
All that you have there is a well used and worn open carrier. I don't even see the pinion gear, without the pinion the ring gear is useless too. The ring and pinion has to match
Best bang for the buck in posi/lockers is the SLP take out units if you can still get them, but then you have to know how to check and set up a rear end, or pay to have it done.
Next best deal is the $300 powertrax lock right locker. It installs in less than an hour and anybody that can half way read and turn a wrench can install it
Old Mar 17, 2005 | 11:59 PM
Car: '82 Trans Am
Transmission: TH475
It sure looks like Auburn Gear's symbol cast into the end of the diff to me:
I wasn't aware that they made an open diff...
If you take that end plate off (the 5 torx head bolts), you might be surprised at what you'll find.
Old Mar 18, 2005 | 06:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is definitely the Auburn logo. It was visible in the other pcs too of course. One of the first things I looked for.
There's numbers stamped on the side of it. IIRC 9 digits, arranged as 3-3-3. That's its model number. Get that # and give Auburn a call and see what they can tell you. That's what I do when I have their product and want to know something about it. They're reasonably easy to get hold of on the phone. Get the # off their web site www.auburngear.com
ZZ3Astro
Aug 13, 2019 12:57 AM
Jorlain
Oct 8, 2015 01:57 AM
InfinityShade
Sep 5, 2015 06:38 PM
Ozz1967
Aug 16, 2015 10:23 PM
