how much fluid to put in the converter
Car: 87 Trans Am
Engine: now a 350
I was wondering how much fluid you need to put into an empty torque converter. I already put a quart in and it looks like it needs more. The converter goes on a 700R4.
Thanks,
Matt
Thanks,
Matt
Car: 4
Engine: 6
Transmission: 5
As much as it will hold, until it spills out when you pick it up and hold it in the position it goes in right before you slip it into the transmission.
I think you'll find that about 2½ will go in there. Maybe more or maybe less depending on what's been done to it.
It doesn't much matter though; the pump will fill it up pretty soonly after you start up the engine. All you need to do is make sure it isn't dry.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
as much as you can fit in there.....
obviously the exact amount changes from converter to converter, but its more then one quart.
1992 Trans Am
May 10, 2023 07:19 PM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
