how many splines??
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
how many splines??
can anyone tell me how many splines an 1988 V6(2.8)/auto firebird axles have???
im wondering because i wanna buy the richmond mini spool, which is only for 28 i believe.. thanks guys
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
26 spline axles. Late 1989 models "might" have 28 spline. 1990 and newer have 28 spline.
The don't make a 26 spline mini spool but you can put 90-92 28 spline axles into any third gen housing to use with a 28 spline carrier. Aftermarket 28 spline axles are much better and are only $125-$150 each.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
actually, it's the 26 splines they make, not the 28, but i wouldn't suggest running a mini-spool on the street. it's gonna kill those axles. if you have to run something that locks, i might look at the powertrax lockers. i know, it's 4x the amount, but well worth not being stranded on the corner with broken axles. a posi unit would be your best bet, and u can usually find them relatively cheap on the web.
Car: 87 IROC L98
I stand corrected. When I picked up some 28 spline axles, I was disappointed to find out they didn't make a 28 spline mini spool.
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I don't know about down there but ....up hear it is a dang hard thing to find someone that will pull apart a rearend...just to give you the axles . They wanna get rid of the qhole thing usually
Engine: 7.0L
so buy some Moser replacement axles and call it a day, they are much stronger anyhow.
Car: 91 camaro rs
so i have 26 spline axles, is that okay for a mini spool, if the car is NOT going to be street driven?
i live an hour and 45 minutes away from the nearest track so it will definately be trailered to and from...
also should i get C-clip eliminators like they reccommend and where do i find them?
Engine: 7.0L
they are recommended for dirt racing only, if you want to, run it, but it's gonna brake axles. they are NOT recommended for Drag Racing.
Car: 87 IROC L98
I've never seen c-clip eliminators for the 7.5" 10 bolt. The diff is just not a performance item for them them to make performance parts for.
Car: 1989 IROC-Z
they got'm .... and are they ever a pain in the ***/$$$$ for so little. I just mean that .....why spend it on the 10 bolt. Screw the c-clip eliminators. Just get rear disc brakes ...that'll keep ya from spitting out the axle .
Car: 87 IROC L98
Rules say "axle retention device" In case the c-clip breaks, something needs to hold the axle in. Rear disk brakes will do the job because the caliper or mount fits over the rotor and holds the axle in case the c-clip breaks.
Car: 87 IROC L98
That's what I just said. My old 9 bolt had disk brakes and tech never bothered me.
codeysabatini
Nov 10, 2015 04:07 PM
Prodigious
Sep 18, 2015 05:23 AM
