How can you tell what stage posi unit you have?
Old Mar 25, 2005 | 04:20 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: built 700r4
I have a posi unit out of a 94 TA that some one gave me but I don't know what type of posi unit it is or what type of gears it will need. Is there a way by looking at it to find out what stage it is?
Thanks.
Old Mar 25, 2005 | 05:49 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
well this wont be much help but ......
if you put the unit ....so the part that takes the gear ...if on the lower side..... mearsure the distance from the table to the mounting flanges ..... the differences sesm to be only 0.25" from a series two ...to a series 3 . but ....I am not sure what the numbers are ...sorry
Old Mar 25, 2005 | 10:02 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
no one else?
Old Mar 25, 2005 | 10:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
stages.. lol thats import talk.
Old Mar 26, 2005 | 08:23 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Seems your a little ignorant on the subject.
Old Mar 26, 2005 | 09:03 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
well if you want me to be on topic and serious, then i ll say you have a stage 1 posi, like the rest of us, cuz GM never designated any axles or parts with stages.
Old Mar 26, 2005 | 11:27 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Here let me help you out because I guess my terminology is not reaching you. I"ll use different names for the same thing.
posi unit=differential carrier
stage=series
considering your the first person to get confused by this I don't feel bad.
Anywho, fbody's that received larger numbered gears stock such as 3.23, and 3.43's possibly even 3.73 received a series or "stage" 3 carrier or "posi", those who used more of a hiway gear received a series or "stage" 2 carrier or "posi"
befor trying to be a smart *** make sure you won't end up a dum ***.
Old Mar 27, 2005 | 12:19 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
ive never heard people use the term 'stage' for axle ratios. only stages i hear about are turbos and aftermarket **** like that. no need to rub it in.
Old Mar 27, 2005 | 12:30 AM
Grizzlee's Avatar
Car: 89 IROC t-tops
Engine: 5.7 (350 tpi)
Transmission: Auto (700R4)
Axle/Gears: 9 bolt disc with 3.73's
9 bolt posi (2 series/3 series)
I am not sure if this will help you....but
If you stick the posi on end and measure up to the ring gear mounting flange you get the following measurement (using a tape measure)
2 series = 5 1/4"
3 series = 4 7/8"
I have a picture of a 2 series and 3 series side by side but I can't get them to show
Old Mar 27, 2005 | 01:06 AM
ljnowell's Avatar
Dont feel bad. I didnt get confused, I just knew that he was wrong. They are not referred to as stages, they are referred to as series.
Old Mar 27, 2005 | 06:52 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I've never heard of "stages" in chevy terms either
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Jan 28, 2016 08:42 AM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
