-AN transmission cooler lines
Old Apr 2, 2005 | 08:14 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Anyone using AN line as tranny cooler line? I figure it'll be much easier to work with. What size are you using? I was thinking about adapting from NPT to -6 and running that right to my cooler. If any of you have done it, how do you like it?
Old Apr 2, 2005 | 09:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Using a flexible line makes installing and removing the transmission a whole lot easier. The ports in the rad are 5/16-IF, not NPT. The transmission case itself is tapped with some size of NPT, but then has 5/16-IF adapters screwed in.
I made my lines out of -6 hose and used Aeroquip FCM-2111 adapters in the transmission and cooler ports.
Old Apr 2, 2005 | 09:43 PM
Engine: LB9/383
so four 5/16 IF male to -6 male and some line. I want to do it while the drivetrain is out of the car b/c it's easier than bending hard line and is more reliable than rubber line. Thx.
Old Apr 3, 2005 | 06:03 AM
ede's Avatar
ede
go to a hydrolic hose shop and you can get a line made with a flare fitting on one end and AN on the other so all you'd need besideds the line is an adapter to go from NPT to AN
Old Apr 3, 2005 | 09:05 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
tranney case is either 1/8" or 5/16" NPT, cant' remember right now. Do yourself a favor, get an after market tranney cooler and bypass the radiator all together.
I'm running -8 out of my tranny in BTE's largest cooler that they offer that comes with -6 female ends so it's all AN fittings. NO leaks ever and easy to install/disassemble. typically run about 120* on the street and yesterday after back to back round robin I got all of 180* in the tranny.
Old Apr 3, 2005 | 12:10 PM
Engine: LB9/383
The cooler in the radiator has been bypassed forever. I've got a perma-cool with a 700CFM fan on it hooked to a manual switch to keep the temp consistent in the staging lanes.
Old Apr 4, 2005 | 10:21 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I made flare unions about 12" below the tranny so you can easily disconnect them for tranny removal. That works great if you have a flaring tool.
I also used rubber lines for the tranny cooler - nice and easy to hook up compared to bending steel lines.
Old Apr 4, 2005 | 06:27 PM
brutalform's Avatar
Installed the largest B&M cooler I could fit in front of the rad. Used Russell -6 braided line. One thing that worked really well, (that I think is worth mentioning.) Use 90* fittings on the cooler itself, but at the transmission, I used two 45* "swivel" ends. It seems to put the lines in the best spot, and prevents binding the lines in any certain position. With the swivels the lines go where they fit best.
Old Apr 4, 2005 | 11:32 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
used straight ends on the cooler itself and 45 degree ones off the tranny....works great. all aeroquip fittings and -6an lines for me. best money ever spent.
Old Apr 5, 2005 | 03:19 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I used straight fittings on all the ports, IIRC.
Old Apr 5, 2005 | 05:20 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
You guys mentioned bypassing the stock cooler, when I bought my aftermarket cooler the instructions said to use the stock cooler inline with the aftermarket one for additional cooling. Did anyone else do that?
Old Apr 5, 2005 | 05:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I use the stock cooler inline with the aftermarket.
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
