How do drive shaft remove?
Old Apr 10, 2005 | 08:20 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
This is a continuation of my speedo gear story.
I got the drive gear and today
I spent the day locating a tranny leak and trying
to remove the driveshaft.
The tranny leak was coming from the tranny cooler line
at the tranny.
I was not successful in fixing it and I was hoping it was
only loose, but I couldnt get a tool in there to find out.
No clearance in there looks like I will have to remove the
dip tick oil tube to have a shot at it.
So I went on to the speedo gear.
I removed the torque arm and cleaned it 1/2 inch of grime.
Then I removed the 2 brackets that I thought held on
the drive shaft but I couldnt remove it.
I looked at the manual and I did what it said only 4 bolts
and 2 bracket retainers then it said to move the driveshaft rear and slide it out.
I cant take it out and I dont want to start hammering away
before I can get some advice.
thanks in advance
Old Apr 10, 2005 | 09:26 PM
rsn932's Avatar
use a prybar to pry it forward a few inches into the transmission. then lower the rear end of the driveshaft so it doesnt hit the rear end, and pull it out of the tranny. it should slide right out.
Old Apr 10, 2005 | 09:27 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
stick a screwdriver behind the ujoint and give it a small tap to work it lose from where it has been set. then the driveshaft should fall, and you can pull it out of the tranny.. pull it straight out.
Old Apr 11, 2005 | 10:00 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Got it done thanks
came off easy with a long screwdriver pryed it out
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
