First question about speedo gears
Old Apr 14, 2005 | 07:47 PM
Abubaca's Avatar
First off, where can I buy "driven" gears WITH THE SHAFT/STEM peice? I bougth a gear from GM that did NOT have the shaft, and the new TCI sleeve also does not have the shaft.
This is gonna **** me off.
Please help
Old Apr 14, 2005 | 09:33 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
GM has those pieces too. The shaft is the electronic sensor unit and the other gear is available from GM too.
Old Apr 15, 2005 | 07:29 AM
Abubaca's Avatar
My car has the mechanical speedo. The sensor is in the dash.
I see you have a 91. I beleive that you have an electronic speedo, correct?
Old Apr 15, 2005 | 09:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check with JMD--I bought both the drive and driven gears from him.
JamesC
Old Apr 15, 2005 | 10:46 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you have the mechanical speedometer, you will need the plastic gear with the plastic shaft (one piece). These are a little different gears than the ones for VSS (with electronic speedometer). What tooth count are you looking for? I can find the part # for ya.
Lou
Old Apr 15, 2005 | 10:50 AM
Abubaca's Avatar
44 tooth.
...I got one from GM for a few bucks, but of course it's the newer style without the stem.
I"ve got a bunch of PN# but I think they're all without the stem.
Thanks for all the help guys.
Old Apr 15, 2005 | 10:56 AM
BigBadLou's Avatar
Engine: TPI
9780470 grey gear.
Or alternate number could be 25522495.
Make sure they know what they're ordering when you give them the number. It's gotta be an all-plastic gear with shaft.
Looks like this:
Hope this helps.
Lou
Old Apr 15, 2005 | 03:26 PM
Abubaca's Avatar
Thanks.
Old Apr 15, 2005 | 03:41 PM
BigBadLou's Avatar
Engine: TPI
No problem, buddy, that's what we're here for!
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
