th350 ?
Old Apr 16, 2005 | 06:19 PM
sgtjackson26's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 5.0L H.O. L69/ shaped to L31R 350.
Axle/Gears: 3.73 Posi
th350 ?
i got an 84 camaro in a field for a bill,put in 350 motor and got a 350 tranny rebuilt and got it in.but i do not now what i need to make it work:ie the linkage i need or how to get the torque arm to bolt up,driveshaft length(6in)and also the best rearend for a daily driver.i could really use a walk through so i dont screw it up.i am also haveing prob with the dipstick tube does not match up.the car used to have a 200 and the crossmember seemed to match up i just think i may have gone over my head on this one but the trans was free and with an 80 dollar kit it is done.please help.
Old Apr 18, 2005 | 10:38 PM
Nordbert's Avatar
The transmission in the picture is not a TH350, but the
dipstick and tube for a late '70's-early '80's Malibu should
fit it to your Camaro. Get a shifter cable bracket for a
late '70's-early '80's Firebird or Camaro w/TH350. Your GM
parts guy should be able to order one for you. The
200 driveshaft and crossmember should fit. There is a lot of
info on this site about the torque arm bracket. The cooler
lines will have to be bent a little to fit. You could make
new ones from 5/16" brake line.
Old Apr 19, 2005 | 08:59 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
not to be a dick, but how is that not a th350? I hve one just like in my garage, and a built one in my car.
Old Apr 19, 2005 | 09:44 PM
Nordbert's Avatar
The rust colored part that is 4" above the dipstick hole and 4"rearward of the top cooler fitting is not found on a TH350.
It is the band adjuster of a TH250 or 250C.
Old Apr 20, 2005 | 11:22 AM
Car: 1982 Trans Am
Engine: 383 chevy
no kidding. I went and checked that out on my car, and I don't have the adjuster in that spot. (phew...) they look identical. is the 250 a good transmission?
Old Apr 20, 2005 | 12:25 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
they are not as strong ,desent though,also geared a little lower
Old Apr 20, 2005 | 02:42 PM
so this is a 250,i was told i bought a 350 AND WHEN IT WAS REBUILT THEY DID NOT SAY IT WASNT.does this create a prob with the motor as far as durability and if it is geared lower i should be okay with say a 273 gear for the rear.i am an engine guy not a tranny guy so please help.
Old Jun 13, 2005 | 04:56 PM
sorry had to bump this.can someone help tell me what tranny this is,is it worth puting in and what do i need to make it work.i get back from iraq in a couple weeks and i need to finish this car.i need a new rear end,and have a 350 crate in it,i wont be driving on the highway but not dragging either.this is my baby and i want to finish this alrready 7000 dollar project.if it is a 200 will it work and what driveshaft,rear end,and arm covertion should i use.
thanks fro the help so far guys.
Old Jun 13, 2005 | 08:17 PM
Car: 1982 Trans Am
Engine: 383 chevy
honestly, I'd stick it in and cal it good. if it was rebuilt, you know it's nearly new, after reading in my tranny books it's the same dimensions as a th350, and it'll use the same stuff. if it blows up, go find one in a junkyard... they're everywhere.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
