Th700R4 problems.
Old Apr 17, 2005 | 03:20 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Th700R4 problems.
Hi!
I have swapped out my old transmission becouse it had no D and OD after a burnout and the rebuilt one comes from a 88 iroc.
Now i cant get any gear in at all,when i roll the wheels i hear a ticking sound like it not attached to the axel or something.
I gyess i have to take it down again.
My question was are the TH700R4 all the same exept for the elektric speedeo?
Thanks for any replay.
Old Apr 17, 2005 | 11:56 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
I take the gearbox down today and foud out that the driveaxel are a little bit smaller on the 88 gearbox than the 92.So i need to change the stallconverter.The only good about it is that i now can take it down and back in 1 and a half our.
I am going to give the transmisionshop a call and maybe they can swap the axel to fit my 88 gearbox so that i can use the stallconverter in that.
Old Apr 18, 2005 | 06:51 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
700r4's made before mid 84 were 27 spline input shafts. Later models are 30 spline. Torque converters are harder to find for the 27 spline.
Old Apr 18, 2005 | 12:14 PM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok thanks.
And what about performance?
Old Apr 20, 2005 | 11:23 PM
Pro Built Automatics's Avatar
The 1988-1992 are very similar, and both are a good start to build from. By the way, they all have 30 spline input shafts.
Old Apr 21, 2005 | 12:02 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
Ok!
The guy that sold me the transmission now say that it is a 87 and not a 88,but i still belive its an older model becouse it has the 3mm smaller axel,its about 22mm and my are 25mm.
Thanks!
Old Apr 21, 2005 | 04:01 AM
The 1987 is still a 30 spline, unless someone has changed the input shaft (to an earlier one), on a rebuild.
MM2Robinson
Oct 1, 2017 09:16 AM
tyeo098
Nov 30, 2015 06:27 PM
bjpotter
Oct 4, 2015 07:48 PM
Camaroguy2
Sep 22, 2015 08:22 AM
camaronils
Sep 20, 2015 02:57 PM
