9" jegs converter
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
9" jegs converter
does anyone run this converter (jegs)... and if so what are your thoughts.... i have read that the 10" tci is good for the money...
I am between two different ones the
TCI-243105
http://store.summitracing.com/defaul...h.asp&N=400252
OR
jeg's 9"plus
555-60422
http://www.jegs.com/cgi-bin/ncommerc...01&prmenbr=361
P.s. i know vig or pro are better but i need the money for the cam and intake swap....HSR/hotcam
TCI-243105
OR
jeg's 9"plus
555-60422
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When buying any converter you always get what you paid for. An inexpensive converter will never be a good performance converter.
A 9" converter can stall higher easier than a 10" converter with the same stall speed. For the 10" to stall at the same high speed, it needs to slip more. The more a converter slips, the more heat it generates.
My current converter is a JW 8" race converter that I paid $1200 Canadian for quite a few years ago. I had it rebuilt locally last year for a couple of hundred bucks. When it's time for another rebuild, I can get a 9" made locally for about $1000 that will be stronger than the 8" and give the same stall speed.
Externally an 8, 9 and 10" converter will look the same. The external dimensions are all 10". The 8 and 9" will have the smaller parts on the inside of the housing.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I ran the Jegs unit for 2 years with great results. very cheap (big plus back then), flashed to 3600 (rated for 3500), and very cery consistent and repeatable in the 1/4mi as far as mph was concerned with no excessive slipping. It was the ideal street/strip convertor and would have no problem buying one again. I believe TCI manufacturers the Jegs convertors anyways.
Waay back then it was just labeled the 3500+
Thirdgen89GTA
Nov 26, 2015 11:04 PM
