one wheel peel action, wtf??
Old Apr 29, 2005 | 05:28 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
somethings up with my rear end, it gets sideways when i turn left, and going straight, but when i turn right, it only spins the right tire. what the hells goin on, can needing a diff fluid change cause this? its a fairly new auburn posi carrier, im not sure how old the fluid is or which rear axle i have. where is the number on the axle to determine which it is?
Old Apr 29, 2005 | 05:46 PM
ede's Avatar
ede
count the bolts in the cover to know what you have. you mean it drags a tire on right hand turns? is it clutch chatter you hear and think it's dragging a tire?
Old Apr 29, 2005 | 05:57 PM
1meanGTA's Avatar
not sure what you mean by clutch chatter or dragging. it only spins the right tire, sometimes the left one will act like it wants to break loose, will kick out sideways for a second, but its always just one black mark i leave when i turn right.
Old Apr 29, 2005 | 05:59 PM
ede's Avatar
ede
i'm still confused, are you saying it isn't working properly or you're being stupid and showing off making right hand turns?
Old Apr 30, 2005 | 06:01 AM
1meanGTA's Avatar
now im confused, you're saying posi rears are supposed to only spin the right tire when you turn right?
Old Apr 30, 2005 | 11:44 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
The whole piont of a LSD is to UNLOCK when turning. It will work just like an open diff when turning.
Old Apr 30, 2005 | 11:58 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, the point of a limited slip diferential is to limit the slippage in the differential. The outside wheel is allowed to turn somewhat faster than the inside one in a turn (or at any time, really). At no point does it unlock or behave like an open differential.
Old Apr 30, 2005 | 02:52 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Im guilty of that
Old Apr 30, 2005 | 04:12 PM
klumb15's Avatar
lol...when you turn its designed to let the outer wheel "slip" so you can make a turn without ratcheting or grinding your gears....also its not a good idea to be burning the tires loose around corners, theres nothing really that cool about that...if ya wanna do some driftin go find a parking lot....i never liked auburn diffs either, they just don't seem or feel as tough as better ones like Eaton...
Old Apr 30, 2005 | 04:33 PM
1meanGTA's Avatar
so basically im describing a normal operating posi rear? why does it spin both when i turn left?
Old Apr 30, 2005 | 04:53 PM
klumb15's Avatar
couldn't tell ya...probably something to do with the weight transfer and how the cluthes release...
Old Apr 30, 2005 | 05:55 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Your right. There was so much confusion I tried to keep it really simple.
Old Apr 30, 2005 | 05:59 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Sounds like your posi is on its way out.
My 9 bolt is completly fried for the most part. On left hand turns, or going straight the posi works most of the time. But when I turn right the inside tire just spins.
Mine needs a rebuild, yours probably does too.
EDIT: Just noticed you said it was fairly recent. It may have been setup wrong which could cause premature wear.
Old Apr 30, 2005 | 06:37 PM
1meanGTA's Avatar
can anyone recommend a good place in west virginia/virginia/maryland/pennsylvania?
83 Crossfire TA
Jan 3, 2016 01:26 PM
DARKmj16
Sep 9, 2015 04:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Randomtask2
Sep 7, 2015 05:06 PM
