lubricant for BW 9 bolt rears?
Old Apr 30, 2005 | 02:12 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
I've read the limited number of posts here and tried to find on google of any mentioning of aftermarket lubricants (non gm part numbered) for BW rears. It seems to be a consensus that Limited slip additive is not needed for BW rears. It also seems to be agreed that 75-80 weight is the ideal weight for street use.
So out of the available aftermarket brands, which do any 9 bolt owners use or recommend for best LSD performance and longevity. I was looking at royal purple but it seems that choosing an oil that has the wrong additives is the difference between having the posi work and burning it out.
Anyone got any favorites?
Old Apr 30, 2005 | 08:01 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
What ever you want to use. Long as you change it when it needs to be done. I've always used semi-synthetic with a bottle of GM limited slip diff. fluid. Any of the gears I've put miles on look mint.
Old May 1, 2005 | 12:34 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
I use royal purple in my 9bolt, don't remember what weight at the moment. Been useing it for 2years now with no problems.
Conrad
Old May 2, 2005 | 05:44 PM
Abubaca's Avatar
That's what I use for my 9 bolt. Valvoline.
Old May 3, 2005 | 12:27 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
amsoil 80w90 synthetic
Old May 3, 2005 | 07:13 AM
safemode's Avatar
Car: camaro rs
how many bottles of Royal purple were needed to fill up the rear? I may have to buy this online since i dont remember seeing it in any stores around here.
Old May 4, 2005 | 11:49 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
For the 9 bolt, I think I sued 3 bottles. But get 4 quarts just for sure.
Old May 5, 2005 | 05:23 AM
3rdGenBlackBird's Avatar
2 quarts is enough....
Old May 5, 2005 | 03:28 PM
twobirds's Avatar
Car: 1987 GTA 350
Yep buy 2 quarts. You will only use 1 3/4 of it tough.
Conrad
Old May 6, 2005 | 12:47 PM
cormyr's Avatar
Engine: 383 miniram
check the fluid capacities in your gm or hanes manual. i bet it says 1.8 quarts. if you don't have a manual, buy one.
Old May 6, 2005 | 04:05 PM
safemode's Avatar
Car: camaro rs
Hanes doesn't give fluid levels for the rear. Neither does the shop manual.
Funny.
Old May 6, 2005 | 04:12 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Conrad
That is my recollection too. I got two bottles of Redline Shockproof and had some left over.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
1nastygta
Aug 8, 2015 07:38 PM
