what does tv cable do
Old May 2, 2005 | 08:16 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
what does it do? I have a 350 turbo w/ shift kit, manual valve body, stall converter ,extra clutches and what not ,trans was professionally built and used just for drag race.
Do I need to hook it up? or not and why?
Old May 2, 2005 | 08:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The TV cable on a TH350 is more commonly called the kickdown cable, it's what forces the downshift when you step on the gas. With a normal valvebody you don't need to connect if it you don't mind always manually downshifting. I don't know how it will work on your manual valvebody.
This is very different from the function of the TV cable on the 700R4, which must absolutely be connected correctly.
Old May 2, 2005 | 08:25 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
so it doesnt have anything to do with line pressure?
its only function is to pull a valve to drop to lower gear?
Old May 2, 2005 | 09:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Line pressure in the TH350 is controlled by the vacuum modulator.
Old May 2, 2005 | 09:17 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
alright thanks, I was told that with the manual body that I did not need to hook the modulator and it has a plug in the spot for it.
I was just wondering about the kickdown I guess I dont need that either.
Old May 2, 2005 | 09:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I think in manual valvebodies like yours they just max out the line pressure and eliminate the vacuum modulator. I can't imagine what the kickdown would be used for.
Old May 17, 2005 | 08:18 PM
87Red305's Avatar
Car: 1987 Camaro
Engine: 305 v8
Could this cable be the reason my transmisison wont shift under hard acceleration?
Old May 18, 2005 | 10:37 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Yes. Without the kickdown it will not downshift by itself under throttle.
Old May 18, 2005 | 02:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It sounds more like he's having an upshift problem, not a downshift problem.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
