longer servo pin
Old Jun 4, 2005 | 01:55 AM
ace16a's Avatar
Car: 1985 Z28 Camaro
Engine: 5.0 TPI
Transmission: 700R-4
Axle/Gears: Posi Richmond 3.73
longer servo pin
I've seen the longer servo pin to use with a corvette servo on ebay and just wondered if it was worth the money or not. Has anybody installed one of these or know if its worth installing?
Old Jun 4, 2005 | 07:47 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: longer servo pin
My Corvette servo was installed today. Another member of this forum put it in and he just used the stock pin.
All I can say is that I was very pleased with the difference in performance I'm getting now as a result. The car no longer has a 1-2, 2-3 flare up between gears. The transmission just pulls a whole lot better. This is a mod I recommend to EVERY owner of a 700R4.
Old Jun 4, 2005 | 10:33 PM
ace16a's Avatar
Engine: 5.0 TPI
Yeah, I already have a corvette servo. I was just wondering if it was worth my time and money to put the longer pin in.
Old Jun 4, 2005 | 10:39 PM
Cadillac's Avatar
Not knowing what benefits are had from the longer pin, I would say screw it.
I've also heard that for stronger shifts you can get a heavier spring that is loaded between the servos and the cap cover. There has to be a name for it. Regardless, I'm good with the way mine is now.
Old Jun 5, 2005 | 03:05 AM
ace16a's Avatar
Engine: 5.0 TPI
From what I understand, the longer pin is supposed to increase the spring tension so the shifts are quicker than what the standard pin gives you. The question is, is it worth taking an already great shifting tranny apart to maybe make it even greater?
Old Jun 6, 2005 | 12:14 AM
Cadillac's Avatar
Simple: No.
InfernalVortex
Apr 20, 2021 11:31 AM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
Dragonsys
Sep 25, 2015 03:51 PM
