I have a Transmission question!!!!!!!!!!!!!!!!!!!!!!
Car: 1989 Firebird
Engine: 408 stroked out to a 427
Transmission: 700 overdrive
I just put in a 408 strkoed out to a 427 small block and i had a 2.8 engine before. i was wandering if my 700 overdrive tranny will be compatable with the big v-8 i was told it will but i am not sure what do you guys think
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
It will NOT bolt up.
The 2.8 V6 is a member of the 60 degree engine family, it has a different bellhousing shape and bolt pattern than the 90 degree engine family, which includes the small block chevy, and the 4.3l v6.
You will need a tranny from a V8. A stock 700R4 will not last very long behind that engine, esp. if you get the car to hook.
Car: 1989 Firebird
so it will bolt up it is just a matter of time when the tranny will be torn up.... i think that is what i am getting from these messages. any ways after i get the money i am going to get a turbo 400 that one will work right?
Car: 86 Camaro
Engine: 2.8L MPFI
Transmission: 700-R4
If thats what your getting from these messages you need to go back to grade school.
Re-read it.
NOT
as in NO
WONT WORK
DIDDO
DITTO
however the hell you want so say NO.
Re-read it.
NOT
as in NO
WONT WORK
DIDDO
DITTO
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
basically, your tranny that was on you 2.8 will not work. you will need a 700r4 from a v-8 engine. the th400 however will work just fine. you just need to get the proper parts for it (transmission xmember, driveshaft. the bracket so you can mount the torque arm to the th400 ect....
Iroc8t8
08-26-2015 08:14 AM
