A bit confused
Old Jun 29, 2005 | 12:42 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
A bit confused
I have flywheels and pressure plates everywhere, and i'm in the middle of doing a auto to 5 speed swap on my car, can anyone post a pic of what the flywheel i should be using looks like ? i have a couple different ones Also if anyone has a hydraulic release mechanism and a release fork for sale plz pm me
Old Jun 29, 2005 | 03:48 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
anyone ?
Old Jun 29, 2005 | 08:06 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
your year of car depends on the bolt pattern on the crankshaft 1986-1987 was the changeover. the amount of ring gear teeth will effect wich starter you will need as well, sometimes you can just change the nosepiece on the starter to accomodate the standard tranny. I can take some pics tommorrow if you can wait.
let me know.
Old Jun 29, 2005 | 08:59 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
let me know.
yep, i sure can, i think i found the right one, but not 100% sure, do you by any chance have pictures or can u decribe also where the hydraulic or mechanical release mechanism is ?
Old Jul 1, 2005 | 12:37 AM
Car: 1986 Trans Am
Engine: 5.7L TPI
let me know.
hey, just wondering if you were able to get those pics ?
Old Jul 1, 2005 | 09:57 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The correct flywheel should be a 153 tooth (small) for a T5 car. If you put a small flywheel over a big one you can see the difference. They are impossible to confuse. The small one is a little over 12", the big one is like 14".
Then you need to know which style RMS your engine has. 1-piece uses a small circular bolt pattern. 2-piece had a bigger pattern, because the crank flange didn't have to fit through the RMS.
Old Jul 1, 2005 | 10:31 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Here is a picture of two 1 piece rms 153 tooth flywheels.
The one on the left is the LG4/ L03 (25lb one) and the one on the right is the LB9 (18lb one).
Old Jul 1, 2005 | 06:53 PM
The LB9 one is the hot one to run if you've got both. The lighter weight will help acceleration, wihout adversley affecting idle quality like a "lightweight" flywheel often does. I've got one on my car now that weighs like 9lbs and the idle is choppy, though my cam is stock.
Old Jul 2, 2005 | 03:01 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
awesome, yeah i have the lb9 one, so i'm gettin that machined today then i'm read to rok
skinny z
Oct 5, 2015 06:23 PM
ndndndnd
Sep 28, 2015 08:00 AM
RS Reaper
Sep 27, 2015 07:04 PM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
