posi problems
Old Jun 29, 2005 | 11:06 PM
darrel88's Avatar
posi problems
i put a posi rear end tonight an its not working at all any more. i took it out and did a burnout they both spun but the right was way darker than the left. so i tried again and now no left tire at all. so my question is do you think changing the fluid to something different would help?
Old Jun 29, 2005 | 11:10 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Is it new? Posi's can wear out ya know.
Old Jun 29, 2005 | 11:12 PM
darrel88's Avatar
no its used but as far as i know it was spose to work
Old Jun 29, 2005 | 11:16 PM
Dirtbik3r's Avatar
I'm going to take a wild guess and say that you put on a 9 bolt. Sounds to me that the posi is slippingand is most likely the cause of worn cones.
Old Jun 29, 2005 | 11:17 PM
Dirtbik3r's Avatar
I just found this. It could help you out a bit.
https://www.thirdgen.org/techbb2/sho...highlight=posi
Old Jun 29, 2005 | 11:34 PM
darrel88's Avatar
thanks for that but i actually have a 3.42 ten bolt
Old Jun 30, 2005 | 09:58 AM
Dirtbik3r's Avatar
Should be the same concepts...
Old Jun 30, 2005 | 09:19 PM
darrel88's Avatar
could it be possible i added to much limited slip additive?
Old Jul 1, 2005 | 09:41 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
10-bolt posi units use clutches and plates with preload springs. Yours sounds like it's spent. You can get the plates, clutches,and springs for about $80 shipped to your door. Try www.ringpinion.com Randy's has all of the stuff to rebuild the unit in stock.
That being said, if you are trying to lay down serious power the stock unit isn't going to last. Pony up to an Eaton or Auburn. I think Eaton has one now with an amazing warranty. It's like if you burn it up they will send you a brand new unit. Not rebuild yours, not send you a rebuilt one, brand new. That's a damn good deal for $350.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
neekolzun
Aug 24, 2015 04:59 PM
mcgarnicle
Aug 12, 2015 04:58 PM
