is the trans going to die on me
Old Jul 2, 2005 | 08:29 PM
peruvious's Avatar
Car: 1991 Z28
Transmission: t-5
i have searched my question for about 2 hours now. i have seen a few people have posted this question but havent gotten any answers. I hope this might be a little different
I have a 91 305 t-5. When im in 3,4 or 5th gear and i hit the gas my engine starts to rev very high but doesnt really go anywhere at all. Also when i am going from 1rst to Reverse i get some grinding noise. Does this mean the transmission is going bad or is it just the clutch. I have to let the clutch pedal out very far before the car starts to go, like the last inch it starts to engage. Help me out please.
also if it is the clutch what clutch would be good to replace it with
Old Jul 2, 2005 | 08:43 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
I am gonna jump on the "you should probably replace your clutch" band wagon. It sounds like it is on it last leg. I will let someone else chimeinon what type to install though. I like centerforce myself. Good luck with your swap!
Old Sep 13, 2007 | 07:37 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: is the trans going to die on me
it's probablt the clutch....sound is probably the pressure plate grinding on the bare rivits of the friction material! with a stock 305...you're best with a stock replacement.
Old Sep 13, 2007 | 02:32 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
also the t5 reverse gear does not have a synchro. Any movement will result in grinding.
eightsixseven
Dec 16, 2024 01:50 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
EFR2000
Aug 18, 2015 08:54 PM
